Wastegate arm shortened to max--is this problem?
Old 15-12-2006 | 02:57 PM
Dragsteer's Avatar
Dragsteer
Default Wastegate arm shortened to max--is this problem?
Hello
I see that my wastegate arm is shortened to maximum (turbo fully opened), but I have Amal valve, and I try set wastegate arm longer, but car goes slow , and have BANG from exhaust.
Is problem and may harm engine if arm is fully shortened?
THANK YOU
Old 16-12-2006 | 01:10 PM
Dragsteer's Avatar
Dragsteer
BUMP
help
Old 16-12-2006 | 01:49 PM
Rick's Avatar
Rick
depends on how much tension u are putting on the spring, but it's easy to knacker it like this.
Old 16-12-2006 | 02:21 PM
Dragsteer's Avatar
Dragsteer
how is serial (original) on S2? for examlpe, maybe 1 cm to max short?
Old 16-12-2006 | 07:04 PM
Dragsteer's Avatar
Dragsteer
Nobody knows?
Old 17-12-2006 | 12:06 AM
antony215's Avatar
antony215
Escort Rs Turbo
One full turn (anti clockwise) of the actuator rod is approximately taking 1 psi off the boost. If thats what you want to know
Old 17-12-2006 | 10:44 AM
Dragsteer's Avatar
Dragsteer
how long is serial on rst? i mean original. 10 psi?
Old 17-12-2006 | 10:57 AM
DazC's Avatar
DazC
Original standard RST boost pressure was 7.25 PSI.
I am unsure what you mean by 'serial'?!
Do you mean how long are the visable threads on a standard actuator? If so, I have no idea!!
If it's the original actuator or a very old actuator, you would be better throwing it away and getting either a new one or a -31 as the springs go weak. It could be that the tension has been wound up to try and compensate for a weak spring.
Old 17-12-2006 | 11:49 AM
Dragsteer's Avatar
Dragsteer
You think that my actuator has gone and because of that my actuator arm is fully shortened, but no boost under 0.5?
how can I test/repair actuator?
Old 17-12-2006 | 06:13 PM
DazC's Avatar
DazC
Feed it with pressure and see what pressure it starts to move at. standard actuator moves at 4psi if I recall correctly. A -31 lifts at 7psi and a -34 at 14psi I think.
Old 17-12-2006 | 06:27 PM
Dragsteer's Avatar
Dragsteer
What needs to move? sorry , stupid question but I am new here
Old 18-12-2006 | 08:49 PM
Rick's Avatar
Rick
the rod.
Old 18-12-2006 | 09:14 PM
Dragsteer's Avatar
Dragsteer
ok thanks.
155lee
27-10-2015 04:55 AM
pabloXR
21-09-2015 12:42 PM
biggiejody
19-09-2015 10:25 AM
Adam Graham
06-09-2015 06:04 AM
rsturbo27
05-09-2015 05:08 PM
Quick Reply: Wastegate arm shortened to max--is this problem?
