excessive play in steering wheel???????
Hi guys. Car failed MOT today on excessive movement at steering wheel. Basically the steering wheel moves slighly around on the column. I thought they were all like this as it is hardly any at all but it failed none the less. What would this be down to? Any favourite/traditional bits to check etc.
Thanks guys
Thanks guys
Escort Rs Turbo
I think there is one at the top of the column im not 100% sure as ive never done one they very rarely go it's a felt bush and i dont know if you can still get them
S1 Database Editor
There's a thread on it in here somewhere, but the search function isn't finding it.
Anyone added it to their 'favourites' file for reference? Also a lad on RSOC asking about this so would be good for him too
Mine was the same,you need to change all 4 steering column bushes.About Ł10 from FORD.Heres some pics of when i did mine.In one of the pics,you can see the difference between the OLD ones and the NEW ones.Pretty easy to do as well.
Tjhe other bush not pictured goes on the top first.Put a post up on here and someone should give you the FIN CODES for them.
Maxxeh
she passed anyway. I just blagged it said I changed the bearing and all mk4's are the same. He said ok no problem lol.
Its actually the whiteplastic bit that goes in the top of the sleeve. It has split. Thanks for your help guys. appreciated
Originally Posted by b_kennedy
Maxxeh
Say what???? Speak up???
A FAG PACKET????
Adam Graham
06-09-2015 06:04 AM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
