Piston help
Old 20-11-2006, 02:48 PM
Fozy
Fozy's Avatar
Default Piston help
Got two knackered pistons with cracked skirts and need to replace them on a standard bore block
I've been offered Escort pistons. Are Escort RS turbo pistons the same as Fiesta Turbo?
Old 20-11-2006, 03:33 PM
davidnormanuk
davidnormanuk's Avatar
Yes. Know this from experience.
Old 20-11-2006, 03:44 PM
SafeChav
SafeChav's Avatar
Indeed the pistons are the same.
Are you sure there is no damage to the bore though.....
Old 20-11-2006, 05:11 PM
JamboRS
focus rs 1672
JamboRS's Avatar
Default Re: Piston help
id be asking why they have cracked in the first place
had same with mine couple of weeks back,sever det cuased the ring lands to crack,no sign of melt,bores were fine,was due to the std breather not being upto the job and filled my intercooler with oil
Old 20-11-2006, 06:32 PM
Fozy
Fozy's Avatar
The bore is perfectly fine. Had it checked as I was going to get it honed. The engineering firm have just said that I should deglaze the block. I bought the engine as a non runner for £40 so I'm not to bothered why. It is merely something to play with to stick im my XR2 for a bit a track fun.
The big end was knackered so whether that added to the issue I'm not sure.
01-11-2015 06:53 PM
little bram
04-10-2015 12:13 AM
deathrider666
28-09-2015 06:12 PM
timsrs
22
24-09-2015 08:14 PM
ajamesc
08-09-2015 06:51 PM
Quick Reply: Piston help
