HELP! MFi Metering Unit Question
MY Series 2 has been sat around for a few months and I was planning on converting to EFi. I've stripped out the metering unit and a few bits, but now I want to put them back in just so I can go get the car MOT'd etc.
The metering unit is back in with everything i can see attached, except for this one part (shown in pics) which doesnt seem to connect to anything. Will the car start as it is? does anyone know what this bit does or where it should connect to?
It Wasnt Me!
thats the CO scre afaik, the thing that sticks up like a knob for want of a better word, is the screw cover, it comes off so you can adjust it, AFAIK! so doesnt need to be attached to anything, jus leave it as is
That thing sticking up is your CO screw. You're meant to be able to push an allen key into it and press the inner part down until it contacts with the screw on the flap arm. Then you turn it to adjust. Usually they are siezed up so you have to remove them and then do it manually then refit after.
chowfornow
14
05-01-2019 09:01 PM
