E.F.I CONVERSION?
Originally Posted by 32a tuning
What about the petrol pipes... you must have to change them.
also you will need a longer coolant hose (or the efi one) for the under side of the inlet manifold as the mfi pipe doesnt quite reach the efi inlet.
Originally Posted by xrchris
mike is your throttle housing turned 90 degrees? mines efi but its a complete engine and loom out a frst
mike i would say ur breather is to high and will not breath right that hi it has to be level with the rocker cover
do u not get water in ur rocker cover that hi? apart from that looks spot on
[/quote]
[/quote]
cheers alex for the comments
. i duno mate to be honest as the car hasnt been run yet. its only just about to be finished. would u say i need to push it downwards then yea so the pipe goin to the rocker is pointing down towards the breather yea?
yes it is mate, and just behind the pulley is the trigger pick up wheel, bought off jano at oddkidd creations, for the sensor to read off of. the dizzy cap is a cosworth one modified to fit onto my distributor with a cossie rotor arm if i remem correctly
the engine bay loom on my car is now a saph cos 2wd one. and thats my original rs turbo dizzy but with a cossie cap on it
mk3ste
Oct 17, 2021 10:09 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
