REAR DISC CONVERSION PROBLEM.
Old Aug 28, 2006 | 07:28 PM
mercury grey minter's Avatar
mercury grey minter
Default REAR DISC CONVERSION PROBLEM.
Am having trouble with my rear disc conversion on my s2.Am using 2wd cossie ones.I fitted them about a year ago ,they were fine for a year but recently they have started binding.Stop great but the y don,t want to let go of the disc.EVEN FAILED THE M.O.T BECAUSE OF IT.I,ve heard this is a common problem,any ideas????Some pics
Old Aug 28, 2006 | 09:23 PM
tim10_10's Avatar
tim10_10
Make sure the handbrake lever is returning properly and cables are free. If the arm is siezed you will need to free off. Might be worth slackening handbrake cable right off, remove calliper from mountings and using the wind in piston tool, wind the piston all the way back in. Then reassemble and pump the brake pedal out and rea djust handbrake.
Old Aug 28, 2006 | 09:26 PM
G420 DEL's Avatar
G420 DEL
as above, also advise remove pads and grease up where they mount, remember that when you jet wash your wheels your also jetwashing away any grease on you brakes..
Old Aug 28, 2006 | 09:29 PM
Wardy257's Avatar
Wardy257
The rear brakes do so little on a FWD car you will always have problems. You will just have to service them every 6 months and keep it all lubricated.
Old Aug 28, 2006 | 09:46 PM
xrchris's Avatar
xrchris
found mine binding although i'm using 4x4 discs and calipers but same principle. as advised already i took mine off today, found piston in and pumped it out a few times on each side then greased up the pad mountings. seems better
chris
Old Sep 17, 2006 | 09:33 PM
white cab's Avatar
white cab
make sure that you wind the pistons fully in on both sides when your changing pads discs, this affects the releasing mech that causes the brakes to bind if you dont wind them home!
Old Sep 24, 2006 | 10:45 PM
Zetecfiesta's Avatar
Zetecfiesta
what discs should you use? all rear calipers are the same aint they i beleive mine are off a granada or scorpio or summit like that!
Old Sep 25, 2006 | 07:33 PM
mercury grey minter
Granada/scorpio are only the same as 2WD COSWORTH and have solid discs.The 4WD COSWORTH have vented discs.If you have got 2WD CALIPERS then only solid discs will fit (THE SAME AS MINE)
Old Oct 3, 2006 | 08:18 PM
cossiemk2's Avatar
cossiemk2
Ok here's another question.
What handbrake cable do you guys use.
I've heard of Mk5 RS2000 one, but there are 2 types.
One with the handbrake in the discs(Mk5a) and the later ones with Granada/Sierra calipers on it, which(according to Ford) is the same as a RS2000 4x4 and Escort Cosworth.
I ordered this but but the outer cable is way too short. But the early type rear discs use a cable with a ball on the end instead of a hook.
I'm really stumped now
cheeRS
Jurgen
Old Oct 3, 2006 | 08:41 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
use red rubber grease if thats any help. on the pistons before pushing them home.
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
rsturbo27
Sep 5, 2015 05:08 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
cossirob
Sep 3, 2015 09:17 PM
