heeelp (up dated)
Old Dec 22, 2003 | 07:27 PM
davie0146's Avatar
davie0146
Default heeelp (up dated)
while driving out to see the wife i slowed down for a speed bump, as i braked there was a loud bang/pop form the rear passanger wheel area. then slight vibrating and a low whing noise.
any ideas what it could be, had a quick look but coundn,t see any thing!!
Old Dec 22, 2003 | 09:44 PM
adamS2RST's Avatar
adamS2RST
Wheel bearing? Wouldnt have thought so, how fast were u going?
Old Dec 22, 2003 | 11:00 PM
sounds like wheel bearing to me to mate not much elsr it could be
Old Dec 23, 2003 | 07:51 AM
davie0146's Avatar
davie0146
was only going about 5-10mph, and it happened before i hit the speed bump!!!
bloody car im of to by a saxo!!!!!!
eh no chance
Old Dec 23, 2003 | 09:31 AM
adamS2RST's Avatar
adamS2RST
PMSL, plz dont !
Good luck in sourcing the prob, u sure it wernt a pot hole or somethin you just ran over?
Old Dec 23, 2003 | 09:57 AM
Got to be a wheel bearing! Wouldnt worry about it as there only about a tenner to buy and easy to fix!!
Dont drive it to hard with the bearing gone as it could knacker the stub aswell.
Old Dec 23, 2003 | 10:36 AM
davie0146's Avatar
davie0146
no not a pot hole, i avoid them like the plague.
probs the wheel bearing,
dont drive to hard!!
how hard is HARD
oh dear we will have to wait and see
Old Jan 5, 2004 | 11:40 AM
davie0146's Avatar
davie0146
well found out what the problem was
it was the left rear engine mount ( near the header tank)
the nyloc nut had come off the bolt and allowed the engine mounting to come loose from the body. the noise coming from the rear wheel arch was the exhaust clatering the underside of the car.
fixed it though , with a trolly jack under the sump a pad made from ploy bags and rice and a sock. slowly jacked up the sump with the pad between the jack and sump and bingo got the bolt though the hol;e and a new nyloc nut torqued to the max.
so go and check your guys, beacuse i never notice it maybe because every time i had a look it was dark.
wonder what else it has fooked up
Old Jan 5, 2004 | 05:50 PM
I had the same sorter noise but was about 2seconds after turning my engine off just a loud pop! Couldnt tell where it was from sounded like xzorst like a back fire pop!!!!Also (droning on now) was driving down A12 the other day and decided to give it some beans (as ya do) and there was three massive bangs from the underside of my car (s2rs) like back fires then cus i paniked like ya do came off and slowly went back on and been fine ever since! except that when i now drive the car and its warm if i sit around 2100rpm it pops like a bugger in any gear go above or below and its returns to normal! any ideas on any of these??? sorry for loading ya people!
Old Jan 5, 2004 | 06:05 PM
RST dont we jus love them if we didnt av 1 what would we spend our money on
Old Jan 5, 2004 | 08:55 PM
Exeter J's Avatar
Exeter J
James:
1. Bang after switching off engine is normal - so don't worry bout this - do you let it run down (i.e. leave it running for a few mins) before switching off?
2. 3 bangs - sounds like overboost or rev limiter coming in to me. Is is chipped and what boost you running? If you cacked yourself - you should see what the cars behind do! (Bang, flash, and unburnt fuel on the their windscreen - nice!)
3. Popping - could be timing is out. Along with above - probably worth a session on the rollers.
Old Jan 5, 2004 | 10:38 PM
adamS2RST's Avatar
adamS2RST
Davie, my engine mount there has gone, and have a croning exhauast, will be chaning it ASAP.
Old Jan 6, 2004 | 12:54 AM
Have had similar before on previous motors, sometimes not easy to pinpoint mate.
Old Jan 6, 2004 | 08:51 AM
davie0146's Avatar
davie0146
BlackS2 will be doing the same myself shortly and possibly the other mounts as well just to be on the safe side.
Old Jan 6, 2004 | 10:47 AM
adamS2RST's Avatar
adamS2RST
Yea, i think it is worth doing em all, £28 odd quid each for ford standard replacement ones.
Old Jan 6, 2004 | 11:32 AM
davie0146's Avatar
davie0146
thats not bad at all
Old Jan 6, 2004 | 03:04 PM
Thanks for the ideas,only thing is its only just come off the rollers then all this starts! Gutted.Also some times cuts out at 4500rpm...its not chipped and running 10psi with magnex stainless straight through and piper x induction got baily dump valve on it too.Ive been recomended to have it chipped and as my tapets have got rather loud ive also been told to fit a new set but am thinking of goin straight for kent camm kit...just money is holding me back...damn crimbo never get back what i spend!!!!!
Old Jan 6, 2004 | 05:25 PM
piper 285 t2 cam m8 i think its better than kent who agrees
Old Jan 6, 2004 | 06:29 PM
Exeter J's Avatar
Exeter J
Bit laggy for around 10psi I reckon (got one in mine), i think the piper 285t would prob be better for fast road use. I don't know anything about the Kent ones.
Old Jan 7, 2004 | 03:21 PM
Damn i hate mixed opinions makes the choice so much harder!!!!!But i think i will go with Kent and give you huys the full report,But i will be running about 14psi when the kent goes in cus want to get it chipped at the same time,But first its those all mighty stoppers i gotta do first gotta be able to stop fast before i feel safe to go fast!
God damn you lot are helpful....thanks
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
3drRich
Sep 13, 2015 07:32 PM
jessie_rs
Sep 8, 2015 04:06 PM
