fuel pump relay?
fuel pump relay?
hi there need some help i try not to post to much.lol, me car broke down this afty after i'd gone in a shop came back out turned over nearly started and that was it just spinning over, fuel pump isn't priming and there isnt fuel going into the fuel filter, at the top hose, can anyone tell me were the relay is to check first before i put a pump on, cheers for the help
The relay is up under the dash on the drivers side.
Before you start pulling things apart i strongly recommend you check for a spark also as it might not be the relay
yup s2, ive checked spark to everything else but not the pump so far as its underneath as you know, only put my proalloy oil catch tank on this morning so highly pissed off, been chcking if its priming, more often than it is, it isn't priming up and still won't start and as i say the hose going into the fuel filter mounted on the inner wing isn't getting anything when turning the engine over?
The reason i said to check for a spark is because the fuel pump relay is tachometric and relies on the LT ignition signals to operate, its very common for the distributors to break down and therefore you lose spark and fuel
The relay is a pinky purple colour. I have some second hand ones if you should want one? Or they are about £25 new from Ford
If you have a spark then i would almost definately says its the relay.
Before you spend your money, get a bridge wire and connect it first to the Black/Red, then the other end to the Red, the pump will run, and see if you can get it running
NOTE: the pump WILL run continuously, DO NOT use the Black wire in place of the Red
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
