piper cams on rst
piper cams on rst
hi there peeps does anyone know if a piper 285 cam will go with an rst not the 285t2 but the normal 285
p.s. does anyone know the diff between the 285 and the 285t2
thanks you for any answers....
differences are the lift and duration, the 285 has a duration of 276 degrees (in and ex) and a lift of 11.17mm
where as the 285 t2 has a duration of 262 inlet and 270 exhaust and a lift of 11.43
i dont see why it shouldnt be ok, you will still get an increase in performance
have a look at pipers online catalouge
http://www.pipercams.co.uk/NewPiperW...CamFrames.html
i've had both & rate the 285t more. the 285t2 seemed to wear real quick
& one of the lifters i got with the kit popped & fooked the head.
the 285t seemed to have a nicer power & it lasted much longer.
although i didn't like pipers shitty attitude so i have used kent cams
since. there just as good. & i have never had a problem with them,
wheras i have seen a few pipers go wrong.
each to their own though. best of luck with your choice
the T2's dont last long at all the last one a m8 of mine had a all new low comp lump done with every thing new, he did just over 1000 miles running it all in, then got it set up to be told the cams fecked
so IMO there 5HIT
mark
so IMO there 5HIT
mark
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
