Upper Boost Limit.
Old Dec 20, 2003 | 11:08 AM
kenny's Avatar
kenny
Default Upper Boost Limit.
Hi. When driving my cars rev limiter comes in at about 4000RPM in 3rdgear and above, which is most annoying, I think this is due to some sort of preset boost limit. Just wondering if its possible to get rid off, or do i need a new ECU and chip?? Any help appreciated CheeRS Kenny
Old Dec 20, 2003 | 12:15 PM
stevo's Avatar
stevo
over boost!!
this happens when ur car is not chipped or the over boost hasnt been removed.
your proberly running 1 bar boost on standard ecu chip
Old Dec 20, 2003 | 12:57 PM
kenny's Avatar
kenny
Ok so now its got a posh name "overboost" How or can i get rid of it? Cheers.
Old Dec 20, 2003 | 04:58 PM
stevo's Avatar
stevo
lol
get your car chipped mate and a -31 actuator then you can run upto 22psi well if u want
Old Dec 20, 2003 | 06:22 PM
flashpoint's Avatar
flashpoint
Get your ECU chipped "job done"
Steve.
Old Dec 20, 2003 | 06:25 PM
Originally Posted by stevo
lol
now that wont be possible with a standard turbo
Old Dec 21, 2003 | 11:08 AM
kenny's Avatar
kenny
Now thats when it gets interesting cos the car is chipped so does this mean my chip has gone wrong??? Kenny
Old Dec 21, 2003 | 11:16 AM
DazC's Avatar
DazC
Overboost is a mode the ECU goes into when it reads more than 10psi of boost. The engine will cut out and not accelerate until you have lifted off the throttle and re applied.
You are either running a 195 bhp chip which still has an overboost facility but higher up the boost range. I think this limits the boost to about 14 psi...
Or you are running an unlimited boost chip which has no overboost facility.
I noticed you are in Blackpool....I would suggest going to see Stu + Kenny @ Motorsport Developments. They will sort you out.
Old Dec 21, 2003 | 11:47 AM
kenny's Avatar
kenny
A chip with a higher boost limit sounds like the fault a possible cure will be to turn the boost down so then the overboost wont come in allowing the car to pull all the way up the revs. Will this work???
Old Dec 21, 2003 | 11:49 AM
stevo's Avatar
stevo
lol
Thats were ur wrong my standard turbo is peaking @ 1.5 bar and holding @ 1.3
Old Dec 21, 2003 | 02:03 PM
DazC's Avatar
DazC
Possibly...hard to tell without looking at the car...
Old Dec 21, 2003 | 03:06 PM
lol
impressive m8, never thought a standard turb would be up for that amount of boost i guess it must be well on its toes then..
Old Dec 21, 2003 | 07:33 PM
stevo's Avatar
stevo
u never no im waiting for the bang
Mind u boost guage could be gay but me mate is running 18psi and he said my turbo is bloody loud compared to his
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
