Efi Conversion Crossover Pipe
Old Jul 14, 2006 | 12:17 PM
davidnormanuk's Avatar
davidnormanuk
Default Efi Conversion Crossover Pipe
I am wanting to keep my MFi Crossover Pipe as its all nice and polished but am converting to EFi. I've noticed the EFi pipe has an additional pipe for the ISCV (idle speed control valve) but on the MFi doesn't have this pipe. Is there any way round this?
I was thinking about running a hose from the outlet for the dump valve to it which should work but looks a bit dodgy.
Dave
Old Jul 14, 2006 | 12:27 PM
Oranoco's Avatar
Oranoco
Just blank it off mate. Bit of hose and a blanking bung. Or get it welded up.
BTW SAY NO TO DUMP VALVES
Old Jul 14, 2006 | 12:49 PM
davidnormanuk
I am needing the extra pipe with going EFi but the MFi one doesn'e have this pipe.
The part with the arrow on is the part I need as I'm going efi. The one underneath is the one I have now and want to keep. Just had a throught though I could use the hole on the other side as the charge sensor goes on the inlet manifold on the EFi.
Old Jul 14, 2006 | 01:45 PM
SafeChav's Avatar
SafeChav
Oranoco you plank you're not on form lately.
HE NEEDS THE EXTRA PIPE NOT TO BLANK ONE OFF
davidnormanuk, keep your bling crossover pipe, and buy one of those breather filters to go straight on the ISCV.....job done
Old Jul 14, 2006 | 01:48 PM
davidnormanuk
Cool cheers mate. I thought the ISCV might need the pressure from the charge pipe to work. Makes my life a little easier then. Turning out to be easier than I thought this lark. Why didn't i go for this earlier.
Old Jul 14, 2006 | 01:50 PM
SafeChav's Avatar
SafeChav
No the only reason it goes into the pipe is so it draws in clean air from the filter, fitting a breather filter is the same effect.
Indeed EFI is easy, wish i could pull my finger out and START mine
Old Jul 14, 2006 | 02:11 PM
Oranoco's Avatar
Oranoco
Ah damn it. Must need a vacation
Just as well I fly out tonight for a holiday
Old Jul 14, 2006 | 02:14 PM
SafeChav's Avatar
SafeChav
No one gave you permission to gloat
Any spares seats for a charitable case?
Old Jul 14, 2006 | 05:01 PM
Oranoco's Avatar
Oranoco
Fraid not unless Uncle Bulgaria or Tobomorie drop out
Old Jul 14, 2006 | 06:23 PM
SafeChav's Avatar
SafeChav
You womble
mk3ste
Oct 17, 2021 10:09 AM
Cosnada
Jan 7, 2016 05:30 PM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
