1.8CVH?
well people will tell you bad things bout everything but there are alot of factors to bare in mind. As above ferriday do a very good package and regarding the 1.9 cvh they can be very reliable it just depends whos built em. But yes you can bolt your head up to one, and ferriday uses zetec pistons in his conversion by the way.
a young lad had one in his escort cabriolet a couple of years back, 1.8 from the sierra and it run like a bag of shit,he had no end of problems with it it used to go up the road popping and banging and misfiring.he then scrapped it and went on to do a 2.0 zvh conversion,so from what ive seen id give it a wide berth.
HTH
regards rick e
HTH
regards rick e
Havent read the topic only the title..
The 1800cvh has the same rods and crank that is used by WELL KNOW ENGINE builders, for their 1900cvh engines
The rods and crank fail with your Grandad driving so god help the poor engine if Turbo'd
Declan Gallen
14-02-2013 01:14 PM
barrychambers30
26-08-2011 06:39 PM
