Fitting a swirl pot to a series 2 escort turbo...
Ok so my latest ebay bargain is a bailey swirl pot... Problem is it doesnt come with any pipes.. First question please can someone tell me where and how it goes? Do I need different pipes or a blankin thing for the thermostat? Bassically how and where do I fit it? Thanks for your great help in advance once again....
Escort Rs Turbo
Block the hole on top off on your Thermostat housing then the pipe that was on there connect to the top off the swirl pot then you need to cut the pipe that goes from the Thermostat housing to the rad and put the swirl pot in line.
This is the part of the pipe you need to cut out cut the bend out of it and put the swirl pot in
swirl pot
Ah I see mate, so do they have one on as standard? And am I wastin my time puttin one on or will it take out the bubbles and make the coolin system more efficient? Cheers
Yes you're wasting your time the ERST and FRST have aswirl pot built in as standard in th etop of the thermostat housing. It might look pretty but it's going to do fuck all. Sorry mate
