OFAB ECU
OFAB ECU
After some months I have Allready get OFAB ECU ( Big thanks for ON-UJAH ) But now I have a little bit problem... I Have all loom from escort xr3 with lambda probe... And now how to get this with the ecu?? witch pin should I change??/
Never will it be a MK4 XR3i loom with a lambda sensor...
The cars only ran up to 1990, a few years before cats were introduced into the law.
To run OFAB on a standard XR3i EFI loom is a very simple job indeed. You need to research your loom more and find out exactly what it is.
shane: never fear SafeChav is here
By any chance.....is this a foreign car its been removed off? I know there was never any UK MK4 1990 EFI XR3i's with lambdas or cats on them........
EFI XR3i's over here on both 89 and 90, were not models with a lambda.
I doubt anyone on here will be able to help you on this, i certainyl can't
Your loom may be compatible, if not you can make it compatible but obviously there will be wiring work involved, what exactly i cannot tell you unfortunately.
You need to acquire a wiring diagram really
DixieTheKid
14-09-2015 09:04 PM
