WHEELS STILL RUBBING
ok here's the situation i had my car on 45mm springs with koni's on front and standard shocks on rear with 17's which was way to much for me so ive gone for 30mm drop on 16's but still with standard shocks on rear and the rear wheels still rub when im goin over bumps and with people in the back etc. i know that the spring will travel more since there higher but why is it still rubbing even with 16's??
but i dont know if im being stupid but i thought that the front end of the car sits lower than the front but lookin at mine the rear is sitting lower im gettin some koni rear shocks fitted in 2weeks will this cue the problem or are the springs fitted the wrong way round??
thank you
thank you
st170 breaking
blimey dont loow very low, mine was lower on 17's and dint rub atall
if its just when you hit a bump then it could be down to shocks not taking the shock but otherwise dunno it shuddnt rub really
thinkin on it my arches have been cut back
Mines a lot lower than that and on 17s and does not rub only if you go over a huge bump fast but thats only on rears as it catches a little on body kit....
well i dont know what sgoin on with the dam thing im hoping the springs have been fitted the wrong way round which goes where the short ones at front and longer ones on the rear??
well its goin to APT in 2weeks hopefully they can sort the piece of crap out
thanks for the relpies
i never knew they did setups thats handy to know thats what mine need but need but thats the last thing imin on july 1st at 11.00am maybe see you there dude.
Adam Graham
06-09-2015 06:04 AM
