Help - Brake problem!!
Old Apr 21, 2006 | 05:32 PM
DanS's Avatar
DanS
Default Help - Brake problem!!
Just fitted rear disks to my car yesturday and all seemed fine. Until i drove the car. No braking power until way down the pedal.
Not a problem i thought, just bleed the system. Which I have this morning, getting plently of fluid from each caliper with no air bubbles...... but still no braking power till the pedal is at least 2/3 the way down but feels fine when the engine is off. Also pedal does not come back up very quickly!
Any advice would be very much appreciated please
Dan
Old Apr 21, 2006 | 05:59 PM
adamS2RST's Avatar
adamS2RST
Oh how I've been here before.... - Fooking nightmare!
Old Apr 21, 2006 | 07:29 PM
DanS's Avatar
DanS
HELP!!!!
Old Apr 21, 2006 | 07:31 PM
Moonie's Avatar
Moonie
You may have to unbolt the rear calipers so the bleed niple is at the top. Even though you are getting no air from the rear brakes there may be an air pocket in the caliper cylinder as the bleed nipple is not at the top.
Old Apr 21, 2006 | 07:44 PM
notSteveS2's Avatar
notSteveS2
as above i had this prob b4... i put my cossie brakes on with nipple wrong way round...
check that first!
if not may b a problem with ur vacuum hose off the inlet???
Old Apr 21, 2006 | 08:14 PM
shane's Avatar
shane
also if you've left the rear weight actuating valves on, then you have to have weight on the rear wheels when bleeding to bleed them properely!
its a pain in the arse!!
Old Apr 21, 2006 | 08:53 PM
DanS's Avatar
DanS
aha! my bleed niple faces towards the rear of the car so I need to move the caliper so it faces upwards?
When i bleed the car the rear suspension ares where on axcel stands and so the bias valves where always open so i cant see that being the problem.
Thanks for the ideas guys
Old Apr 21, 2006 | 09:06 PM
ian r's Avatar
ian r
as moonie says had same problem last week
Old Apr 21, 2006 | 09:18 PM
pau1rs's Avatar
pau1rs
nightmare job....
but make sure you get the bleed nipple to the higest point and you won`t believe how much air is trapped!!!
give it a go and hopefully you`ll be sorted...
Old Apr 21, 2006 | 09:34 PM
DanS's Avatar
DanS
Sounds like this could be the issue then! Fingers crossed this solves the problem, I'll be out there first thing tomorrow taking the calipers off. If not its no Santapod for my car
Old Apr 21, 2006 | 09:52 PM
adamS2RST's Avatar
adamS2RST
What are you using to bleed the system? I found an eezibleed pressure kit worked well. And oddly enough over the course of a week my brakes did get better themselves...weird.
Old Apr 21, 2006 | 10:01 PM
DanS's Avatar
DanS
Yeah using a pressure kit which is hooked up to a tyre valve. works very well.
Old Apr 22, 2006 | 08:42 AM
SteveB's Avatar
SteveB
Dan,
Remember when I was bleed the system on thursday I showed you that the caliper had to be moved so the nipple was at the top to get all the air out.... .............. I knew there should have been a written exam afterwards to check you were paying attention in class
Old Apr 22, 2006 | 10:32 AM
DanS's Avatar
DanS
pmsl steve
Just bleed them again with the calipers on top of the disk and air bubbles came out of both calipers so hopefully thats done the trick. just waiting for the paint to dry before putting the wheels go back on
Fingers crossed!!
Old Apr 22, 2006 | 10:37 AM
adamS2RST's Avatar
adamS2RST
Did you bleed the whole system or just the rears again ?
Old Apr 22, 2006 | 12:10 PM
SteveB's Avatar
SteveB
Hopefully..... the whole system (well thats what I sugessted last night)
Old Apr 22, 2006 | 06:23 PM
DanS's Avatar
DanS
All sorted!!
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
