christmas tree lights
basically my rear clusters are lookin light christmas tree lights when brakin indicatin etc, if i fiddle around with them i can get it to work, but to be honest i don't know what i did to make them work ive replaced the clusters themselves had a look at the wirin etc and i can't find anythin wrong, just wanderin if any1 has any suggestions cause its mot time
i had a probelm befor like this, i found that the connections had corroded, causing the the lights to malfunction. If you have replaced the clusters then this may not be the problem tho it may be worth checking.
alternativly if the foam seal around the lights fails you can get water ingres aging causing problems or the final thing may be a poor earth or dodgy wiring.....
does this happen on both sides of the car or just one and what lights are affected is it just the brakes and indicators or is it them all???
its all of em mate, fogs reverse, indicators, brakes, from what the passenger side seems to work fine when the drivers side isn't connected but when it is they all go, but with a bit of fiddlin and playin about with i can get them to work, as soon as i shut the boot or somat they all go haywire again.
foam seal shouldn't be the problem cause its been garaged for several months.
think its a bad earth just can't figure it out
yeah the wires have been cut to the cluster before i owned it, prob an attempt to solve the prob, so not sure whether the brown is the earth, my wiring is completly different to me mates turbo, the colours aren't the same.
ooked all the connections over and cant seem to find a prob,
ill try some electrical contact grease and see if that solves it
cleaned & greased everythin up, now im gettin everythin except sidelights on the drivers side & indicator on the passenger side. tried different clusters/bulbs, any other ideas?
Everywhere that there is a contact give it a clean, its usually the wiring plug to be honest, they corrode and go dry. You want something very mildly abbrasive to just clean up the contacts a bit, getting there though
go into halfords and ask at the parts desk to look at the mafco stuff some stores still stock clusters and some stock the connector i fitted new ones on mine sorted it straight away
this is becoming a right pain in the arse, ive basically got em all workin perfectly except for the drivers side light on the rear cluster which is because it keeps blowin the fuse evrytime i turn em on! been through 4 now, just wanderin if any1 has suggestions
not that i can see, ive changed the fuse for a 15 amp, higher than it should be but seems to be holdin out & thats solved that problem, it all runs great i put the clusters back in place & now when brakin & indicatin on the passenger they both flash. think im just gonna ave to take it to a spark. problem is its not mot'd
its a series 2 turbo mate
drivers side cluster & plug
http://img.photobucket.com/albums/v3...2/DSC00036.jpg
http://img.photobucket.com/albums/v3...2/DSC00035.jpg
Passenger side cluster & plug
http://img.photobucket.com/albums/v3...2/DSC00034.jpg
http://img.photobucket.com/albums/v3...2/DSC00033.jpg
http://img.photobucket.com/albums/v3...2/DSC00031.jpg
Frog Tosser
the connectors are a pain, I knocked them on the head and cleaned up a good set of clusters then soldered the connections on, so no plug. I also put vaselene in each lamp holder (ask the missus to go to chemist)
Not had any problems since
must ave happened when i pulled the plug off, i made sure they were all in the contacts, i might try gettin rid ov the plug, ta for all the help with this, its really been pissin me off
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
