fuel pump HELP!!!!!!!
Old Apr 3, 2006 | 06:03 PM
webby80's Avatar
webby80
Default fuel pump HELP!!!!!!!
my fuel pump just packed was wonderin if anyone knew if the xr3i pump is the same?????
Old Apr 3, 2006 | 07:09 PM
originalcabbie's Avatar
originalcabbie
I dont think so the pump will get you about but I beleive the XR3i one is about a bar of pressure short of the turbo one.
Old Apr 3, 2006 | 08:02 PM
HORNETS7's Avatar
HORNETS7
ON THE OTHER HAND I'M SURE THEY ARE THE SAME?
Old Apr 3, 2006 | 08:58 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
try and see
dont forget to disconnect the battery first as sparks,around the tank and petrol mix nicely into FIRE
Old Apr 3, 2006 | 09:46 PM
SafeChav's Avatar
SafeChav
Akito-man you are just sooooooooooo helpful
I'm sure they are the same, if its any concellation my Turbo has the original XR3i pump??
Old Apr 3, 2006 | 10:25 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Im also sure they are the same (MFI anyway) as are cosworth fuel pumps
Old Apr 4, 2006 | 07:33 AM
originalcabbie
hmmmmm. I may be wrong but I am sure I saw an Autodata printout saying that an RS turbo fuel pump worked between 4.5 and 5.5 bar of pressure, where as the XR3i fuel pump was 3.5 - 4.5 bar of pressure or sumthing like that, I'll check and get back to you.
Old Apr 4, 2006 | 03:24 PM
James Raby's Avatar
James Raby
Don't care about flow rates, but I have one if you need it
been sat for about 2 months, worked fine beforehand
let me know
Old Apr 4, 2006 | 04:15 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
I've heard 3i ones ain't up to it aswell
you checked the relay though?
Old Apr 4, 2006 | 06:26 PM
originalcabbie
I had a check on Autodata the XR31 feul pump operates at 4.5 - 5.5 bar of pressure, the RS tufbo runs at 5.5 to 6.0 bar.
So you can use an XR3i pump but it is operating at max to give the rs the corrsct fueling. I would personally get a turbo feul pump as it will last you longer.
Old Apr 4, 2006 | 06:32 PM
SafeChav's Avatar
SafeChav
Is the autodata quoting the fuel system pressure or the pressure the pump can produce? I think it will be the pressure the system operates at, in which case if it is the xr3i pump should be the same. Have a look on microcat, i was lookng the other day im certain they have the same part number, cossie ones im sure are different though, as they are the same as the 2.9 granada pumps.
Old Apr 4, 2006 | 07:16 PM
James Raby's Avatar
James Raby
They are the same number, as is every other fuel injected 1.6cvh
Old Apr 4, 2006 | 07:39 PM
SafeChav's Avatar
SafeChav
Good good i thought so
Old Apr 4, 2006 | 08:11 PM
akito-man's Avatar
akito-man
back o the net ,hey safechav
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
