Who has drilled their block to take a CPS?
Has anyone successfully drilled their block to take a EFI cps? If so has anyone got any pictures? I'm a bit jubious about doing it and also wanted to see how others have done theirs
It will be coming out......the reason i ask is because on a factory set up the hole is very big, and that adapter plate bolts in, then the sensor goes into that, i wonder if anyone has done it any other way, but then i should imagine its tricky getting the clearance right.
Hmmm, problem is the engine isn't being stripped down its only done 3.5k on a re-build. So its not going to be easy getting a whole engine on a milling machine surely?
A drill that has an electromagnetic base. You can switch it on, and it will hold itself to the end of your block, allowing you to drill at a perfect 90degrees.
Steve
a decent milling machine will easily fit the engine on it
the one ive got waiting to do is a short block with sump on still
i think its a 30mm bore and a seperate m6 hole
Thats the problem though my engine has the head and everything still on it, and i'll be damned if its coming off i've already had the head off once in 3.5k miles
Originally Posted by Jano_OddKidd
Sod all that!!!
Just fit a bottom pulley with the trigger setup built into it.
£45 Job done
Bolt it on and away you go
£45 Job done
I presume you use the sierra 1800 pulley yeah?
Ask me a question!
Sod all that!!!
£45 Job done
£45 Job done
What a load of waffle mate.. Who told you that you have to drop the engine..
It make it so easy to change a belt that you dont even need to take the bottom pulley off Nothing to do with droping the engine...
Well you haven't answered the question i asked you yet. Using a sierra bottom pulley (which is what i asked you and you didnt reply to) you HAVE to drop the engine.
Maybe im just lost without the pretty pictures.
Well i'm sure where theres a will theres a way like anything but i don't fancy pinching the belt forcing it through a small gap. I didn't think the pulley would allow a good clearance?
Fook me that looks like you did a good job of it. How the hell did you drill a hole of that size with a hand drill
Ah ok I was looking at the block again yesterday and its only about 4mm thick isn't it? Is the material very hard to drill through?
Thanks very much for the offer, worst comes to worst im sure i could bring it you
I'm guna give the hand drill a go though i think JesseT did an excellent job, so i'll have a bash
Where do you mount the sensor in this case?
