MK5 clutch conversions
Originally Posted by dave_y
i bought the parts today and they cost Ł21.
AP recommend the upgrade as the pedal will be stronger to use with an uprated/heavier clutch.
Get some smaller hands? Get the missus to do it?
It is quite tight!
Make sure you protect your eyes when you remove the pedal box pivot retaining clips as they have a tendency to flick off at high velocity!!
It is quite tight!
FPMSL will have a look for my long nose pliers!
duly noted, will arrange some goggles lol. i couldn't see much under there anyway had the sun shining right in my eye!
mk 5 pedal
you dont use the spring ratchet or quadrant, junk it all it works with the pressure from you pressing the clutch and to stop the quadrant springing back too far you use the m8 locknut. make sure you put the m8 locknut on back to front as it will eventually cut into the quadrant and brake it if you dont.
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
