cams
cams
I need a new cam, would i better of with an uprated one ie piper or kent, or stick with a standard jobbie?
Its only a standard engine with stg 2 hybrid turbo and chipped ecu.
What ya reckon?
need a cam kit by the way.
cheers
Benn
What ya reckon?
cheers
Benn
Had 2 kent cams in mine (cvh34), but had problems with em so switched to a newman cam now....and to be honest the kent was better imo, if they hadn't given me any trouble would have stuck with it! Really useable power band, very little lag and pulled like a train to the limiter
Originally Posted by Tony Turbo
I wouldn't use a Kunt cam Benn, shockingly bad for wear Pooper aren't much better either.
Location: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
luck of the draw,fuck that, giz £230 ,and ill send ten thai girls around to sex you up,if there not there by tonight (when ive had your cash),theyre not coming,luck of the draw!
id expect them to be ok for thousands of miles.
#1 in Spelling Club
Benn, the Standard Ford cam would be OK for that spec.
Alternatively, I would suggest a Piper 285T.
NO WAY is another Kent cam ever going in my engine. We had 4 cams that all ran lobes off within 1000 miles. All in different engines, only one of them built by us.
All cam manufacturers appear to be struggling for decent quality blanks and the followers are mass-produced shite, so that's a struggle too.
The only way to be more sure is something like a Newman solid profile, there is definately a noticeable difference in quality there, but it is slight over-kill for a low/moderately spec'd car. This is mainly due to the increased setting up that these require.
See, IMO, the std cam is good for bigger turbo engines, where as the uprated are when the std head and turbo hosuing is used, the valves are held open longer for to compensate for their restriction.
Mc5506
05-10-2015 09:57 PM
