when using a decomp plate ??
Old Mar 9, 2006 | 05:14 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
Default when using a decomp plate ??
do i use 2 head gaskets , or seal the plate to the block or just fit it flat
if i have to seal it what should i use peeps
anyone got any info in this or anyone running on , info would be appriceated
thanks
beef
Old Mar 9, 2006 | 05:17 PM
thelynx's Avatar
thelynx
I personally wouldnt use one.... But if I had to I would seal it, then use a single gasket
Old Mar 9, 2006 | 05:20 PM
-beefy-'s Avatar
-beefy-
more its the cheapest option bud , just need the car going and got 90 percent of the parts together ,
in a perfect world ive have a new set of low comp pistons but , on budget at mo
what would u use to seal it ???
Old Mar 9, 2006 | 05:31 PM
andre_k's Avatar
andre_k
no more nails
Old Mar 9, 2006 | 07:39 PM
-beefy-'s Avatar
-beefy-
funny fooker lol
Old Mar 10, 2006 | 09:09 AM
ivorbiggun's Avatar
ivorbiggun
Felpro make a product called 'brush tack' liquid gasket sealer.
put that on the deck surface followed by the plate, lastly the gasket.
Finally IMO one of the best tenners you can spend when doing
these kind of jobs is Snap On tool No FAM8E for your head bolts/
cos they NEVER slip or chew the hex and allow you to torque
the head down correctly.
Old Mar 10, 2006 | 11:21 AM
Rick's Avatar
Rick
i can't help thinking what a waste of time this is. Why not just use a cvh bottom end with std pistons?
Old Mar 10, 2006 | 03:27 PM
ivorbiggun's Avatar
ivorbiggun
There's no replacement for displacement...
Old Mar 10, 2006 | 06:27 PM
-beefy-'s Avatar
-beefy-
lol , tried to ring colin at mad for it , number not in use at the mo
have to try and find some of that "brush tack "
mates got that snap on part already bud !!
just a cuple of bits to do now ,
still need to find a cheap turbo ,
rember im on budget lol
thanks for help guys
Old Mar 10, 2006 | 09:35 PM
ivorbiggun's Avatar
ivorbiggun
Sorry Beefy
I didn't think to give you both... 01579 321735
or
www.mad-for-it.com
Old Mar 10, 2006 | 09:44 PM
Rick's Avatar
Rick
That is one of the stupidest phrases banded about by people who haven't got a clue. If your goal is power, or torque for that matter, then on a turbo car you are limited by how much air u can flow, and strength. Using the std pistons out of a zetec means u are are going to break things v quickly with only 200hp.
Old Mar 10, 2006 | 09:55 PM
T28 RST's Avatar
T28 RST
Ok then
How reliable is it going to be with a decompression plate
Old Mar 11, 2006 | 08:14 AM
swerv's Avatar
swerv
remember your budget when it goes tits up and you have to do it all over again.......false economy my friend.
i would seriously seek the advice of a pro and take it from there.
rs turbos are not to be run on a tight budget let alone modified on one
Old Mar 11, 2006 | 12:28 PM
Rick's Avatar
Rick
Never a truer word said! They are NOT cheap cars!
Old Mar 11, 2006 | 01:27 PM
-beefy-'s Avatar
-beefy-
appriceate what u posted guys ,
but why the heel do they make them and why do people use them if the re soooooo unreliable ???
, ant i aint going for masses of horepower , just need the car running ,
boost wont even be getting turned up ,
be left as standard
now any comments on the subject or we gonna start blabbing on about how much they cost cos belive me i know !!!!!
Old Mar 11, 2006 | 03:07 PM
Rick's Avatar
Rick
they probably can be made to work with limited power. But, when the std cvh can do lots more power and be reliable...... thats what i cant grasp...
Old Mar 12, 2006 | 02:04 PM
-beefy-'s Avatar
-beefy-
rick mate ,
already had the 1.8 motor in the garage , and 90 percent of the other bits needed bud ,
so far its set me back about 80 quid in bits and peices to get it where i can get it in the car and runnin ,
my cvh motors goosed ,
needs a full overhaul regrind shells rings pumps ect ect ,
looking at least 500 sheets to get that sorted ,
and when i get working again then , a propperly specced +built engine will follow ,
and seeing as im at the point now where its nearly done apart for a cpl little things ,
it will just have to go in and c how it does now wont it boys . !!!
howayyy the boro !!!
Old Mar 12, 2006 | 02:15 PM
Rick's Avatar
Rick
well, good luck with it
Old Mar 12, 2006 | 02:37 PM
-beefy-'s Avatar
-beefy-
change of plan , pistons are coming out and getting skimmed
should be a bit safer , foud a bloke who can do it for me
bobsworth
77
Mar 24, 2016 09:30 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
