problem
Old Mar 5, 2006 | 06:00 PM
grunter's Avatar
grunter
Default problem
when running if i remove the oil filler cap the car carrys on running is this a bad sign???
Old Mar 5, 2006 | 06:24 PM
James Raby's Avatar
James Raby
It should stall
I would check all breather pipes are free of blockage - be careful as they snap easily!!
Old Mar 5, 2006 | 06:45 PM
Micky's Avatar
Micky
As above check all breather pipes (No James, Im not stalking you're posts ),the main one I was always told to check is the pipe from the back of the rocker cover down to the sump.Regards Micky
Old Mar 5, 2006 | 07:16 PM
stevedb's Avatar
stevedb
Why should the car stall??? Should a fiesta turbo engine stall??? cause i have fiesta turbo engine in my cab and it dosnt stall with the oil cap off.
Old Mar 5, 2006 | 07:27 PM
Micky's Avatar
Micky
A Fiesta wont stall as it runs EFI,but a ERST is on MFI and should stall if running correctly.Regards Micky
Old Mar 5, 2006 | 07:30 PM
SafeChav's Avatar
SafeChav
A standard engine as said should stall, have you got a different breather set up? I've disconnected my breather system from the air box just to eliminate the whole engine as a potential air leak.
Old Mar 5, 2006 | 07:35 PM
James Raby's Avatar
James Raby
all opinions and advice matters here mate
Old Mar 5, 2006 | 07:39 PM
John Laverick's Avatar
John Laverick
A standard car should stall as the fueling system requires a sealed system and you are basically introducing a massive air-leak.
If you have a modified breather system you can run a non-sealed system but the fueling needs adjusting to suit. My car is on MFi and doesn't stall if you remove the oil cap.
A Fiesta is EFi so I would imagine you could remove the oil cap without it stalling.
Old Mar 6, 2006 | 06:05 AM
grunter's Avatar
grunter
its totally standard even down to the air filter i was thinking along the lines of the breather system but then someone kept saying rings it has done 11600 miles but like i said is totally standard..... i aint brought it yet cao im tryin to find a good shell to reshell it into cos its rotten as a pear
Old Mar 6, 2006 | 12:36 PM
SafeChav's Avatar
SafeChav
I did have an RS i bought a long while back before i really knew anything and im sure the rings were gone cos it smoked like a bitch u could follow the trail of smoke and find me it was that bad, and that would run with the cap off. It was RAPID though
If your rings were gone i would think you would be seeing other symptoms like excessive breathing and smoking out of the exhaust.
Old Mar 7, 2006 | 06:04 AM
grunter's Avatar
grunter
thats the funny thing it dont smoke lol..... looks like im not bothering now cant find a good enough shell for the rite price got my eye on summat else now lol
Old Mar 7, 2006 | 12:51 PM
JesseT's Avatar
JesseT
If it doesn't stall, but is MFI with standard breathing, then it's just simply running rich.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
