braking
braking
on a s2 rs turbo would it be easy to do a disk conversion on the back using the origional front calipers.
i was wondering if it would be hard to do or not good cause people never seem to do it.
www.ctuceilings.co.uk
Re: braking
I am bored, so I will answer your question, possibly without a sarcastic or even humourous reply for a change.....
You cannot use front calipers on the rear because there will be no way of applying the handbrake, unless you you use a handbrake seperate caliper or some kind of line lock. Pointless doing that. Just use some Cosworth rears like 99% of people do.
Originally Posted by addiction
Being as Christian has over 300 bhp and does not feel the need for them i think that says it all
to be fair christian has HOOOOGE front brakes so can just about get away with rear drums even at his power levels...
rear disk conversion is worthwhile but not essential, even on super specced RST's
Originally Posted by Rallyesport
No racer would dream of having rear drums on his car. Disc give more stable braking, not on off as drums can be. Would be desired on any super spec'd RST.
Your comparison against new cars makes me laugh, how can you simply compare a new car to a 20 year old bean tin is beyond me
Don't you get it? If you want to impove your car, fit newer technology. In the past cars had drums at front too. New cars also have drums, but only low end cars and it's to save money.
I understand completely, but how would we go about getting a fully functional and low maintenance rear disc and caliper kit?
The ones from the cossies are just a pain in the neck
addiction, your reply is 3 replies too late??
He has already explained himself
And that reply is a bit harsh don't you think?
All I was saying is how do you compare old to new, and he said (not fully, but I'm sure we'll get there soon enough)
yeah ok James fair point! sorry rallyesport!
but on the other hand modern cars are designed to run with rear disks and the rst was not. so its just trying to make the most of a raw deal. .all front wheel drive cars do 90% of the braking on the front and only 10% on the rear! (unless you have a bias valve!)
Cant say I've had any of the above issues, either with my previous setup 4pots 308mm disks front (ford disks and calipers rear) nor with the current brake kit.
Both are far superior in braking ability than the 4 pot 308mm front and drums rear that I originaly had.
I agree that caution is needed to ensure bias is correct, as I know of a few accidents that have happened as the result of incorrect proportioning of bias.
I've got the same problem with my rear disc conversion,it only grabs about 70% of the disc.But to be very honest the fronts do 90% of the stopping to be honest.I have a bias valve fitted in car and have had to reduce a shed load of bias too the rear as it kept locking up the rears big time.In my opinion the only real advantage of fitting the rear disc conversion is that the pads are easier to replace than the shoe's.If you upgrade the fronts to big stoppers there's no more further advantage to be gained in stopping power by fitting rear disc's.Best regards Micky
