clutch pedal
clutch pedal
has any1 changed there standard rs turbo clutch pedal for the later mk5 escort adjustable one. If so how did you go about the conversion and how easy was it?
read this
http://www.apracing.com/roadcar/clutch/epmods.htm
done it on my old one works well but only real benefit is if you have a paddle clutch fitted
when you say it works well, what difference did you notice compared to before ?
ive just ordered a new part from fords as mines bust and the car is undrivable
clutch pedal
well i got the old pedal out and b4 i fit the new one i wanted to make sure i do it right. would i be right in saying that the spring from the old pedal is for the automatic adjustment and it wont be needed on my new pedal??? i just fit the cut quadrant as is without any spring????
#1 in Spelling Club
One piece of advise for anyone taking this on.
For the 5 minutes that it takes, remove the drivers seat!! It is a very fiddly job to put the pedal cluster back together and being able to lay on your back comfortably will allow you to make a nicer job of it and prevent you getting a dis-orientation headache!!
Besides you can have a little kip halfway through the job if you want.
Originally Posted by mercury grey minter
Make sure you cut the tab off the new mk5 pedal otherwise it will not work properly.
Especially when you flick the clips of the end of the pivot rod and they whack you in the face
clutch pedal
thanx for all the replies chaps, I now have a clear idea of how to do this. I just need to cut the tab off the new mk5 pedal like mercury grey minter said. Thanx again
