fitting dump valve to small turbo escoss
I've just bought a dump valve relocation pipe and bailey dump valve is it just a matter of fitting it or do i have to do something to the existing dump valve on the turbo
any help
any help
Re: fitting dump valve to small turbo escoss
any help
any help
Originally Posted by ECOS95
You should have blanking plate to replace the exsisting one by the turbo.
Chris.
Chris.
Originally Posted by bam
so does that mean you can place a bailey one where the standard one was and run it to athmosphere instead of running it back into the air trumpet to the turbo ????
steve
Steve
Steve
steve
You cannot use it on the ST Escort then. The air which it releases has been measure by the MAF sensor and if it does't stay 'in the system' then the ecu thinks the engine is getting more air than it actually is and over fuelling occurs. Lots have tried normal dump valves and had poor idling issues because of it. You can only fit a recirculating dump valve such as the Bailey DV30 on your car.
rsstav
Ford Focus RS Parts for Sale.
16-08-2015 08:38 AM
rsstav
11-08-2015 04:22 AM
Red_bull
09-08-2015 08:34 AM
