escos boost????????????
hi everyone just a quick question how do you work out 1 psi to hp if you work it out like that
well main question is my ecos is needing more boost it running L8 a1 rally chip t34 stage 3 hybrid bd14 inlet cam bd10 exh cam wrc head gaget full s/s exh group a fuel pump group a dis group a filter low comp manhal pistons fully lightend and balanced ap clutch 3 bar map air /air rs500 cooler samcos an running 24.5 psi just wanting know what power i should expected and iv been told to turn it up tp 34-35psi is this to much what are you lot running and what power should i expect from the car it only done 6k on rebulid any help pls thanks
roughly 5hp per 1psi raised if u can get it fuelled
!!!WARNING!!!
you say you think its got a low CR, you really need to know for sure and get it live mapped or at least setup propery - literally, acouple of 100£ will save you £1000'; if u just wind it up and it goes pop
!!!WARNING!!!
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
