Help required please.
Old Dec 23, 2005 | 03:04 PM
auralisRS's Avatar
auralisRS
Default Help required please.
Firstly, just got my head back from machine shop and one of the coil packs has bust in transit... (anyone got a second hand one they want to sell)
I could also do with the part of the manual that explains how to line everything up again....ie cam pulleys, etc. Pretty standard stuff I know, but I want to get it right....
Thanks guys.
1996 Escort Cos.
Old Dec 23, 2005 | 03:07 PM
Damo V's Avatar
Damo V
Dont take this the wrong way but there is quite a few complex essays in the tech essay section, though you have to be a gold member
Alternatively do a few searches as its been covered alot
Failing that a technicians manual will help no end... POP up on EBay regularly
Old Dec 23, 2005 | 03:09 PM
Damo V's Avatar
Damo V
Just had a quick look
There are a few cd's available..
http://search.ebay.co.uk//search/sea...worth+workshop
Old Dec 23, 2005 | 03:19 PM
auralisRS's Avatar
auralisRS
Yeah I use ebay a lot, I did look prior to posting, but thought a quick scan and post would be quicker from a member....especially this time of year...Id have no chance.
Thanks for your help
Old Dec 23, 2005 | 03:22 PM
Damo V's Avatar
Damo V
It will be about 6 pages
Old Dec 23, 2005 | 03:36 PM
Damo V's Avatar
Damo V
When installing the cylinder head gasket fit alignment studs as shown.
Auxiliary shaft and distributor rotor it, tdc position
Slackening and tightening sequence for the head bolts
Alignment studs
Lubricate head bolts at threads and under bolt head and install bolts together with washers.
Tighten cylinder head bolts as follows:
Stage 1 requires to tighten all bolts 30-35 Nm.
Stage 2 requires to tighten all bolts to 67 -70 Nm following the sequence.
Stage 3 requires the bolts to be tighten in degrees of rotating using a special gauge tool.
Following the sequence, each bolt is turned 80° - 90° of rotation .
Check and ensure that the crankshaft, the camshafts, the auxiliary shaft and the distributor rotor are still in TDC position. Fit the timing belt in counter*clockwise direction starting at the auxi*liary gear.
• Pull belt tensioner by hand in clockwise direction against the timing belt and tighten fastening nut.
Crank engine several times in clockwise direction and subsequently one full turn counter - clockwise to TDC position.
Note: The engine must not be cranked beyond TDC position.
Using the belt tension gauge 21-113, check belt tension at the longest straight section (see illustration). If necessary adjust belt tensioner so that the specified tension of 9,5 to 10,5 is achieved.
Repeat complete procedure and recheck belt tension.
Crankshaft, camshafts, auxiliary shaft and distributor in tdc position
Old Dec 23, 2005 | 06:47 PM
auralisRS's Avatar
auralisRS
Thanks very much for all the Damo. Much appreciate it.
I wonder what the cost of a Coil pack will be...
Old Dec 24, 2005 | 02:37 PM
Damo V's Avatar
Damo V
A1 Rallye sport apparently... £35!!
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
20/20 vision
Sep 29, 2015 09:25 PM
