Wolf Injectors
Wolf Injectors
I write to ask if there is someone that can tell me the code for this kind of injectors (installed by Wolf) and if there is some data about them. They are beige coloured and the rest of the body isn't black but raw polished metal as the ones in this photo. One of my injectors blow too much petrol and appear to be broken... so i must probably change it.
Is there someone with Escort Cosworth Wolf experience/knowledge?
Do you think that green (803) fit well in substitution of alls? Car (ECU) is set for 300Cv.
Help me please
Thank in advance.
Help me please
Thank in advance.
Thank to all!!! Finally i was able to read the code of this injectors. They are Weber Marelli IW 058 3239/D. I found that are mounted also in Lancia Delta Evo kat and they throw 384cc/min. But a friend told me that the problem is made by cold sparks Champion C57N. Now i try to take out and take some check and evenctually put the original ones (less cold).
I'll report all at the end of the tests. Thank you to all for your interest. I think this forum is a wonderful place to be in.
Originally Posted by JHS
Standard Wolf injectors on big turbo Escort are yellow....
Are you sure that they are installed by Wold?
I know someone who had exactly these injectors installed and they were not from Wolf but from Suhe Motorsport if I remember correctly.
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
