6pots on esc cos
6pots on esc cos
Ive just put ap 6pots and 330mm discs on the motor and the brake pedal is softer than a sponge.Is there a special way to bleed these calipers or do I need to bleed the rear as well?
not being funny, but there is no need to bleed at least a pint out at all, unless u are replacng the whole fluid with srf say,, u only need to bleed out until it comes clean with no air bubbles in.
Exactly but mine and Glens 6 pots took a pint of fluid each nipple to show clear
you may be lucky m8 and do em in like 100mm fluid each but i doubt it
500ml will do a whole brake system front and rear, and yes bleed the rears too after the fronts, ensure all air is out and as clear as possible without going silly on quantities
