Changing engine coolant
Old Nov 18, 2005 | 01:01 PM
MATCOS's Avatar
MATCOS
Default Changing engine coolant
I am going to be changing my engine coolant over this winter, is it a simple case of removing bottom rad hose and flushing through with cool water, or is there more to it, also when I fill it back up again am I right in saying that there is a bleed screw on top of the thermostat
cheers
Old Nov 18, 2005 | 03:38 PM
Damo V's Avatar
Damo V
Yes warm the engine, not hot but warm, allow the system to build up pressure, then drop the guts through bottom rad hose... That obviously wont get all the old stuff out but alot will come out
I theory you chouldnt put really cold water into the header tank as it will cause an immediate contraction of the block/head, which isnt ideal... if you plan to flush it through with fresh water it may be a good idea to use boiling / hot water, then again get car warmed up, drop all the water out bottom rad hose,
Ideally have the front of the car higher than the back and as it warms up there is an 8mm bolt in the top of the therm housing, undo this a little and you will see water trickle down the side of it.. thats it just do it up again
Old Nov 18, 2005 | 03:43 PM
MATCOS's Avatar
MATCOS
Thanks Damo
cameron2
Aug 25, 2015 07:18 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
muffster
Aug 17, 2015 08:17 PM
