CLONKING NOISE WHEN PARKING
AS ABOVE I HAVE GOT A LOUD CLONKING NOISE WHEN PARKING MAINLY. AS YOU TURN THE STEERING YOU GET A LOUD BANG WHICH SOUND LIKE IT IS COMING FROM THE DRIVERS FRONT WHEEL AREA I HAVE CHECKED ALL THE JOINTS AND CANT FIND ANY SIGNS OF PLAY AND I HAVE FITTED A NEW BOTTOM JOINT I CANT THINK WHAT ELSE IT COULD BE ANY IDEAS APPREICIATED
Had a similar sounding problem with my car,above the top spring retainer on the front leg there is a cup that holds a bearing,there is a nut above this that is only meant to hand tight ,but at some stage it had tightened causing the bearing to seize and shear through the cup,it caused a 'clonking' noise on the steering but more noticibly when parking this was because the spring wouldn't turn as much as the rest leg and would come a little un-seated.
I HAVE HAD IT ON THE PIT AT WORK TODAY AND IT DOESNT SEEM TO DO IT UNTIL IT GETS HOT SO I AM THINKING IT MIGHT BE SOMETHING TO DO WITH THE STEERING RACK ALTHOUGH THERE DOESNT SEEM TO BE MUCH PLAY WHEN THE ENGINE IS RUNNING AND IT SEEMS TO BE SMOOTH WHEN YOU TURN IT LOCK TO LOCK I WILL CHECK THE TOP STRUT MOUNTS TOMMOROW IF I GET TIME TO SEE IF THERE IS A PROBLEM WITH THEM CHEERS FOR THE HELP
i havent got round to checking the top mounts yet but i have tightened the rack mounting bolts up and this has helped but have strill got a bit of noise i may get some more rack mounts did you get yours from ford ? damo
No Brom@Zoo mate 35 quid IIRC
Honestly before you Łcuk about with the legs etc, get under it agaain and rock it left to right with IGN off mate. You will see the rack move and if you put a long scredriver onto the rack amnd the other end onto your ear, you will hear the knock through it..
BTW If you have std bushes in your rack you will need to take rack off to fit new bushes/pop old ones out
HTH
Damian
HTH
Damian
In my case no, the rack didnt have to come offf, but thats because I already had some modified 909 2 part nylon bushes in there, so I just drilled them to soften them then popped them out, just pullyng the rack forward from the crossmember slightly, BUT if you have std bushes they will need pressing out in a vice etc, so sorry yeah rack out, alternator off etc etc (though again I didnt have to take alternator off as I have modified my crossmember just as they do on the grp N cars )
rsguy
44
29-09-2015 03:29 PM
