Turbo heat shield bracket?
Because I have removed my airbox and now use a cone filter there is nowhere to fit the top mounting point of the turbo heat shield. It is now only held in place by the bottom and middle mounting points.
Has anyone made a bracket for theirs or do most people just leave it with 2 mounting points?
1 Post
as above, my pipercoss kit came with a bracket to mount the heatshield, it was only a thin bit of strip metal, v easy to make one.. like this.... (cue daves quality paint drawing)
I had a K&N cone filter on mine but i didnt like it so i junked it...i might still have the bracket that you want lying around...i will have a look 4 it 2morro if i get time,but i can't guarantee that i still have it but if i have you can have it m8
Robski Cheers, top man! If you do find the bracket let me know and I will send you a cheque to cover postage and a couple of pints!
bracket
Simon Day
hi m8,found the bracket...although you will have to find the nut and bolt that u need to fix the bracket onto the heat shield/body. im sure this is the bracket you need as the only other bracket supllied in the K&N kit is the bracket to hold the 2 air feed pipes to the cone and that isnt straight like ths one....i hope this is the one u need. Just send me your addy and i'll put it the post 4 u 2moro,if u can send us your details b4 2nite i can send it tomor otherwise im out of town for a few days and i will have 2 send the bracket when i get back.
cheers
Rob
cheers
Rob
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
track.focus'd
12-08-2015 05:53 PM
