Small turbo to large turbo conversions
Which companies make these in UK? I'm asking because I'm still trying to find the T25 escort dissy connector (camshaft position sensor) and I tought I could ask from some company if they have any.
Originally Posted by THE RADMAN
do you mean the multi plug electric connector? think ryan on here does all that stuff
Surely if you are converting to big turbo and using a cam sensor you do not need to connect the t25 'dissy',this only needs to be left in place to drive the oil pump??
Right, there seems to be some confusing, in the UK, that sensor and the one you have pictured, is not actually called a camshaft sensor, its called a PHASE sensor, i think people are getting confused as there thinking your going to be fitting a CAMSHAFT sensor which actually goes on the camcover and uses a totally different plug fitting.
If you wish to retain your orginal phase sensor then yes you will need to find an old plug to re-use.
Hope this clears things up for people
I believe yrkesman is correct generally this item is known as a Cam sensor, only as it isnt placed on the cam, it is labelled as a phase sensor, though still often refered to by technicians as a cam sensor, as thats what it does
What he is after Ryan, incase you can source one is the loom plug which mates onto the plug in the pic .... I think...
steerfromdarear
28
29-01-2016 06:14 PM
Matt Baxter
16-09-2015 08:30 PM
