quick shift kit
Old Oct 24, 2005 | 08:19 AM
Robski's Avatar
Robski
Default quick shift kit
Anyone got a quickshift kit on thier esc cos?...and if so is it any good and what brand is it?
cheers in advance
Rob
Old Oct 24, 2005 | 09:53 AM
dojj's Avatar
dojj
Resident Wrestling Legend
rally design
Ł40+
you need to have a bit of patience fitting it
well worth it
Old Oct 24, 2005 | 10:48 AM
Kelv's Avatar
Kelv
Almost there!
As above, had this one on both my escorts and rate it very highly.
Rally Design
Units 8 - 10 North Quay
Upper Brents Industrial Estate
Faversham
Kent, UK
ME13 7DZ
www.raldes.co.uk
01795 531871
Old Oct 24, 2005 | 05:30 PM
cozzymatt's Avatar
cozzymatt
B&M... ands its really crap dead notchy, did reduce the throw but it was a nicer drive as standard...
Matt
Old Oct 30, 2005 | 02:06 PM
july1's Avatar
july1
I've juste fitted my B&M and if the feeling is like as I expected in a shifting point of view (I Guess it won't be differante than the Rally design one) but I'm quite sade as the feeling with the lever itself is really poor! there is a sharp angle on the top which is very bad and there logo on top almost worse
When I look on what I paid for that compare to the rally design one I would'nt advice to my worse enemy to buy a B&M
Old Oct 30, 2005 | 02:48 PM
big-dirty-dog's Avatar
big-dirty-dog
so the b&m shift replaces the whole standard gear stick,where as the rally design one replaces just the bottom part???????what if your standard shifter is fooked is it better to buy b&m or what?????
Old Oct 30, 2005 | 07:25 PM
july1's Avatar
july1
I would suggest to buy the RD bit and a second hand gear stick to built something ready to be fitted it will still be cheaper than the B&M for a better feeling.. but that's my feeling.
Old Oct 31, 2005 | 04:54 PM
Simon Day's Avatar
Simon Day
I bought a graham goode "GGR 059 4wd Quickshift" because I was told it was about the best to get and it uses the standard gear knob.
I have not got round to fitting it yet though so I don't know how good / bad it is from a personal point of view.
Anyway - how do you fit these kit's and are they easy to fit?
Old Oct 31, 2005 | 05:59 PM
dojj's Avatar
dojj
if you are going for the 4wd kit then you need to get the cradle off from the box
this means dropping the box (literaly) so you can get to the bolts to undo the cradle and unclip the selector
then it's a question of pulling the hwole caboodle apart (you need small screwdrivers and circlip pliers and a vice and a spanner and a punch and a chisel (screwdriver) to bend the locking tab over and a bit of hammering, that sort of thing) to get it in bits to swap the little lever thing apart
once it's all apart the metal bit pops out of the plastic housing, you refit this with the new one and away you go
with one hand (broken left wrist in plaster) it took me 5 hours, on me tod
the most difficult part of the whole swap is getting to the bolt on the drivers side of the transfer box (it's a left hand job ) but i think i've got some pics about
Old Oct 31, 2005 | 06:01 PM
dojj's Avatar
dojj
thats the bit you are going to change
and thats what you need to pop out
it comes out of the top but you can't get to the top without getting it off from the bottom, and due to the nature of the fittings you need to get the cradle off first
Old Oct 31, 2005 | 07:54 PM
cozzymatt's Avatar
cozzymatt
So true.. focus rs gearknob fits straight on and really does look cool...
Old Nov 1, 2005 | 07:24 AM
july1's Avatar
july1
Do you mean on the B&M stick???
Old Nov 1, 2005 | 07:39 AM
july1's Avatar
july1
No this is wrong!
You 'just' have to unscrew the rear shaft bearing put to box on a jack take the gearbox cradle out (the whole cradle) and then lower the engine/box assembly
You will just have enough room the remove the rear screws of the lever cradle.
Then you can remove the boot from the spherical pivot bearing casing, remove the axis that connect the lever to the shift rod! (to unscrew the nut you just unscrew it! No need to unbend the washer)
Finally you take the circlip out from the inside with the lever and you fit everything together back with the new quick shift... (there you’ll have to use a little hammer and a piece of steel to bend the washer to secure the nut)
Two of my m8s did it this way.
Or alternatively you wait the have to upgrade (or renew) your clutch to remove the box totally like I did
Old Nov 1, 2005 | 04:19 PM
Simon Day's Avatar
Simon Day
shit in thought it was an easy job!
Old Nov 2, 2005 | 04:46 PM
dojj's Avatar
dojj
No this is wrong!
but why?
you would have to remove the prop to do this and it serves no purpose, the bolts that you can't get to are the ones at the top of the cradle
but the washer locks the nut in place
you can't unscrew the nut wit the washer in place because it locks into both the hole in the bottom and over the nut
i can see that this will need pictures to explain, they will be up when i get home
Old Nov 3, 2005 | 10:29 AM
july1's Avatar
july1
No this is wrong!
but why?
The point is you dont need to remove the 2 screws on the top but only the 2 on the side the front bushes will do the rest.
Son you don't remove the complete shaft but only the bearing to allow the box to be lowered.
I juste said that you don't need to waste your time to unbend the washer with a hammer but simply use a wrench to unscrew the nut! (it will unbend the washer with no effort and put less stress on it so it will better if you dont plan to change it
Old Nov 3, 2005 | 06:06 PM
dojj's Avatar
dojj
i can't move the sofa out of the way to get the whole box out but you can see what i mean (i can't move the XR out of the way to get the trailer out of the way to get to the 24V lump out of the way to get the gearbox outside either and for the life of me i can't rememerb wehre i've put that little shaft that goes from the bottom of the selector to the gearbox so you'll have to bear with me)
but
the little knob at the bottom is what you need to disconnect from the rest of the selector shaft that goes into the gearbox, and while i can see that the other way would possily work, i think it's much easier to do it my way
you can see the bolts that i have removed from the front and there are 2 on the side (one either side) to pop out and then you can just pop a pin and out it comes
daylight and some bodies to shift stuff about will yeild more pictures unles someone else can come up with the goods?
Old Nov 5, 2005 | 10:58 AM
july1's Avatar
july1
Note that I didn't said tha your ways was wrong but only that it was possible to do it with the box on the car this to save time and health...
Old Nov 5, 2005 | 05:52 PM
dojj's Avatar
dojj
i know
thats why i wanted to see if you way was workable too (obviously it is as you've done it) but at least now there are 2 tried and trusted ways to do it that people can have a go at
Old Nov 5, 2005 | 07:18 PM
july1's Avatar
july1
I guess some have smalest hands than other
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
