Short Shift
i used to have one on a previous cos,they do make it notchy but very precise,cant remember what make it was but it was a replacement knuckle that fitted onto the orig stick
I'have got a B&M but it will be fitted only in next few weeks :°(..
the one radman is talking is the 'swedish' version.( that are the only two possibilities i ever saw).
some poeple says it can increse the wear of the syncromeshes but it will depend how hard you are with when shifting...
If like me you find the travel is too long you should try it!
I'll let you know my feeling as soon as posible but it may not be very accurate because I'll fit a paddle cluch at the same time
ive had a couple on both escorts now and also driven one with the B&M shifter.
to be honest i preffer the small nuckle version, it felt alot more precise and i was able to keep the original gear-nob.
only down side with the B&M is that it replaces the whole stick aswell.
try www.raldes.co.uk for the nuckle replacement... costs around Ł60.
Kelvin
Kelvin
No prob, rally design are decent chaps, theyve helped me out with alot of bits over the years and have come to know them really well.
only down side if you change the nuckle is that you will have to drop the gearbox to access the selector cradle.
Kelvin
Kelvin
Yep!! Furgot about the conecting clip, should manage to get to it by lowering the box down on the cradle on a trolley jack. Looks like its going to be a dirty job again.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
