Injectors 803 on escos small turbo
Originally Posted by Azrael
What do you mean by stage 2 i EEV - IV equipped car?????
fuel pomp,and biggest injectors but which ones???
'cause originals can't go up to 270 hp
There is no such thing as MSD stage 2 chip. And originals will go up a little more then 270bhp - or at least Stu says so. How can you choose ijectors if you already got a chip????
http://www.motorsport-developments.c...data/index.php
I thought that these ones are stage 2,I have not already a chip but before buying
it, I'd like to know what kind of injectors will fit it with such a chip !!
The site says everything. Stag. 1 kit includes (from memory) fuel pump, wastegate actuator, chip and that's all -> with exhaust and air filter gives 297 bhp. I got this convertion. It's not like you can fit some kind of injectors with a chip. Chips are made for certain injectors.
I run std injectors on std pump @ 303bhp/297lbft
EEC4 small turbo model.
t28
Stainless- no cats
stainless cone filter
Cams
Chip
Before cams it was 287bhp
t28
Stainless- no cats
Cams
Chip
Is it special chip for those cams?
EEC4 chips are like bluefins and the range of parameters is massive, so airflow meter/lamda etc keeps the ECU upto speed!!!
OK - I'll be waiting :-D
OK this will have to wait some time, unless I have to change cams for some reason (standard sometimes crack).
Just driven ~400bhp Escos wich everything well sorted out apart from Koni suspention which is shit :-(. Incredible car. Now I know why Motec Management is so good :-D
why can't you get any more power out of the t25.
what about putting a t34 compresser housing on the frount
of the t25 and a 5 injector?[could that work]
my rover ecu can't be chiped so i added another 4 injector's
running off a hks injector controller this is how i get more fueling
i keep on thinking i could do the same to my escort
Most probably because EEC IV MAF sensor and MAP sensor are limiting factors. Stu@MSD explained couple of times to me that it's not worth the developments cost when there are other aftermarket ECUs on the market.
will the map sensor be out of it's range [ie boost]
what about putting a bigger maf sensor on i think they
do that to supra's
hks do a vein presserure converter which replaces the
mass air flow meter's
any one herd of epec this interfaces with eec iv via piggy back
and was used on mustangs and cobras i read this in a mates book
have to find out more
do that to supra's
MAF and MAP sensors can be changed, it's a question of deciphering the code to find the settings. The MAF_TRANSFER_TABLE is easy to find as it's similar code to a lot of Zetec ecu code but the MAP sensor is harder as the turbocharger control and boost fuel/spark adjustment part of the code is 'tacked on' to what is essentially a normally aspirated ecu code. It's this decoding that takes time and what Stu is refering to is that no one is likely to pay for the time to find this all out.
The EPEC (Extreme Racing Engine Control) ecu was a replacement for the eec-iv by Ford SVO (I think it was based upon the A9L Mustang ecu) that could be programmed via a laptop. As far as I know it was only for 8 cylinders and a lot of the fine control we come to expect from a daily driver was stripped out.
There is a few alternative ways to keep the eec4 ecu.
HKS AIC running 4 addition injectors ontop of the std ones.
Unichip running 4 additional injectors on top of the std ones.
You could also run a 5th injector like we used to on the RST's in the 'olden days'
Problem with both tehse ways is the vast cost and the fact that it is cheaper to go for weber management or even scrap the ford stuff and try omex etc etc which can run any resistance injector etc etc, but unless you are planning a 500bhp monster, probably abit of a waste
I have driven Motec managed EEC IV Escos last friday and the difference is so vast it's worth every penny. Engine behaviour on and off boost is so amazingly different. It's so smooth, throttle responce is like motocyckole not old Ford-Cosworth engine. Shocking difference. I don't know if it was mapping or just the menagment being better. Still I'm amazed. And there of course features -> driving additional gauges, shift lamps, data logging, ALS, water injection, lots and lots and lots.
we just Omex'd a small turbo escos at work, it was a nice convertion, dark greens & about 22psi peak saw it make just over 300bhp & 340lbs/ft
Matt Baxter
16-09-2015 08:30 PM
