Jacking points
Old Sep 14, 2005 | 03:27 PM
Franco's Avatar
Franco
Default Jacking points
OK so where's the best place to jack an escort up form on the rear??
Need to get to the fuel tank to change the pump! Never had her up in the air except on garage ramps........
Cheers all!
Old Sep 14, 2005 | 04:58 PM
Glenn5's Avatar
Glenn5
i used drive up ramps m8 no need 2 remove wheels remove rear bumper and your away change fuel filter while under there aswell only real problem is seized rusty tank strap bolts
Old Sep 14, 2005 | 05:46 PM
Franco's Avatar
Franco
Sorry Glenn did you still remove the rear bumper??
Old Sep 14, 2005 | 05:58 PM
Glenn5's Avatar
Glenn5
yes sorry not very clear, remove bumper m8, you can get to filler neck pipework with wheels on mite pay 2 pressure wash out the rear arch first and a real good top tip when tanks out remove petrol cap(and pull off colour coded ring be carefull they can be quite brittle) and twist fuel filler neck and remove clean behind where it sits and waxoyl it m8.
Old Sep 14, 2005 | 06:00 PM
Franco's Avatar
Franco
Well played Glenn
Old Sep 14, 2005 | 06:02 PM
Damo V's Avatar
Damo V
Yup as above but if you do want to jack it still, use the big donut bush things in front of the rear wheels
Old Sep 14, 2005 | 06:52 PM
Azrael's Avatar
Azrael
Yep, or you can jack it under the rear diff. But rear beam mounts are great for that.
Old Sep 14, 2005 | 07:49 PM
THE RADMAN's Avatar
THE RADMAN
i always use rear diff as well,easiest place
Old Sep 14, 2005 | 07:57 PM
lamb chops's Avatar
lamb chops
Rear diff is an approved jacking point, just looked at the ford manual
Old Sep 14, 2005 | 07:59 PM
Azrael's Avatar
Azrael
Wonder what is good place from the front. I jacked it under TCA mount to crossmember couple of times, but is there better? Front diff is bad idea I think...
Old Sep 15, 2005 | 09:54 PM
Damo V's Avatar
Damo V
Middle of front subframe
Old Sep 15, 2005 | 09:58 PM
Azrael's Avatar
Azrael
Middle of it? I was told it's possible to crack it that way....
Old Sep 15, 2005 | 10:11 PM
Damo V's Avatar
Damo V
Its in the Manual...
Old Sep 15, 2005 | 10:13 PM
Azrael's Avatar
Azrael
I've got it, but you know tthere are errors in manualas sometimes. Somebody on PF told me that it's bad and one can crack sub-frame. But maybe I am wrong. I did jack it like that no problems though
Old Sep 15, 2005 | 10:17 PM
Damo V's Avatar
Damo V
I have always used that .. with a bit of wood... had my subframe off recently werent any cracks that I saw
I also used the ARB but not now its powdercoated lol
Old Sep 15, 2005 | 10:18 PM
Azrael's Avatar
Azrael
i HAD MINE EXTENSIVELY WELDED AND REINFORCED RECENTLY AS THERE WERE LOTS OF CRACKS AROUND ENGINE MOOUNTS. (sorry for caps)
ARB? I wouldn't think of that.
Old Sep 16, 2005 | 03:32 PM
Franco's Avatar
Franco
No worries lads..........I used the rear diff & the subframe on the front!
But thats all a much longer, deeper story!! But i'm now!
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
