Whats the noise
Whats the noise
I have a annoying noise coming from under the car when you take your foot off the clutch pedal. Its hard to explain buts it sounds like a rattle its quite loud. My mate reckons its the transfer box it does this after any sort of run out. It has got louder from when i first got the car is it anything to worry about? Is the transfer box about to give up?
Yeah it goes when you dip the clutch. I have changed the release bearing so its not that. The clutch has been changed just before i bought it perhaps i should get a new one?
So if you sitting on the drive in neutral it rattles and chatters about, till you putt the clutch down?? You are stage III aint ya?? .... YUP that'll be the gearbox(or Transfer)
Go out give it a DAMN good hammering ESPECIALLY in third, then it will made the most awful noise you have ever heard and you will need to buy a new gearbox
chech the prop shaft, my girlfriend heard a noise like that from under my escos
the next thing i new the prop shaft let got smashing the diff and gearbox.
mine makes a silly noise but only when i select a gear nothing wrong tho my clutch don't slip and the gearbox dont make any noise bar that.... who knows
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
