Idle Problem
Old Jul 21, 2005 | 06:59 PM
Turbo Chris's Avatar
Turbo Chris
Default Idle Problem
Hi,
On my Large Turbo Esc Cos i have a problem on idling
It idles on about 1500rpm once warmed up
Idles perfect when first started for the first 5 minutes and then it starts to happen again
Ive changed the Idle speed control valve for another one but no change
Can anyone help me as its driving me mad
Thanks in advance
Chris.
Old Jul 21, 2005 | 09:08 PM
july1's Avatar
july1
run an autodiag and you may find a faulty sensor (I don't why poeple doesn't start by this??)
Old Jul 21, 2005 | 11:17 PM
tan's Avatar
tan
I had a similar problem on my large turbo esc cos and was advised to change the ect sensor, its only about £20 and it ran perfect after that.
Old Jul 21, 2005 | 11:55 PM
pixi's Avatar
pixi
My Scort Lrg Turbo is the same, "They R like Woeman - very tempremental", but U love them 4 it....
Old Jul 22, 2005 | 06:37 AM
july1's Avatar
july1
You can get similar trouble with at least ECT,ACT sensor (the only ones I had trouble with) but I guess with a faulty MAP sensor you may have it too.
So do the autodiag!!
(if you want to do another quick test: @ 20°C the values of the ACT and ECT have to be the same so with a cold engine and a multimeter you should find out if one of them is dammaged. (if it's the case I'll let you know the right value so you will be able the change the right one)
Old Jul 22, 2005 | 07:45 AM
Malc50's Avatar
Malc50
HI All
How do you run a autodiag please...
Thks
Malc
Old Jul 23, 2005 | 08:51 PM
Petrucci's Avatar
Petrucci
as above... an autodiag ?
Old Jul 28, 2005 | 06:07 AM
Malc50's Avatar
Malc50
AUTODIAG ????
Cheers Malc
Old Jul 28, 2005 | 07:26 AM
Franco's Avatar
Franco
Take the idle valve off & give it a good spray with WD40 while carefully pushing the piston up & down...........This will either cure it or you'll have to do the above!
The valves have a tendency to stick, a common fault on all Cosworths!! (dunno why any of you never thought of that!!)
Old Jul 28, 2005 | 10:48 AM
red october's Avatar
red october
so did ne1 ever find out what an autodiag was ???
Old Jul 28, 2005 | 10:52 AM
rog's Avatar
rog
Auto diagnostic i presume, like one of those things that plugs into the ECU
Old Jul 28, 2005 | 12:25 PM
red october
the sort of thing we all have lying around in the garage then ???
or should i be going to get one then ?
Old Jul 28, 2005 | 12:49 PM
Malc50's Avatar
Malc50
Anyone have an answer re the AUTODIAG What is it
Thks
Malc
Old Jul 28, 2005 | 01:07 PM
Speedy G.'s Avatar
Speedy G.
As said before.
There are small devices for sale around the globe. You just plug these into a port in the engine bay and you get a readout of which sensor are at fault.
You can make one yourself. Sent a PM to july1 and he can tell you how.
Old Jul 28, 2005 | 07:33 PM
THE RADMAN's Avatar
THE RADMAN
think he means a fault code reader,ive got one but its crap,far too complicated and seems to find faults with everything on the car
Old Aug 5, 2005 | 05:08 PM
red october
now geting similar problem on my small turbo ?
any ideas ? omly when warm & if you turn off & back on again it behaves fine ?????
Old Aug 6, 2005 | 10:44 PM
red october
cured it on small turbo by replacing small gasket btween valve & throttle body !!
(broke intake hose jubilee clip doing it )
Old Aug 7, 2005 | 05:34 PM
july1's Avatar
july1
Sorry guys I havn't read your answers for this post sorry for that!
So, many of you are right I'm talking using a fault code reader (which should tell you if a sensor is dammaged).
I said 'should' because it can only tell you if the sensor (or loom) is cut or in short circuit and sometimes the ACT or the ECT are simply out of there range giving wrong informations to the ECU so you get wrong fuel and ignition timing! but it's the first thing to try anyway.
As I said somewere else another simple test to do is to check ACT and ECT sensors as they share the same kind of resitor, when the engine is cold you should get the same value in the two of them using an ohmeter! (about 3.0Kohm @25°C).
Back on the autodiag now.
I'm sure you should be able to find the complete stuff all of you need by becoming a Goldmenber and having a look to the "Technical essay Archives" section.
If you don't wan't to give 20£ for the forum contact me on MP and I'll see what I can do for you (the point is I don't have it in english...)
For information to built you own reader you just need an old type voltmeter (needle type) or a 12V led (led + 1Mohm resitor), a piece of wire and a paper clip!!!
That's why this test worth to be done
Just one final word about the T25 (small turbo cossie) as most of you knows the use the Ford ECCIV ECU then this test does't apply and you'll need to go to a Ford dealer to read the fault codes..
Old Aug 9, 2005 | 07:42 PM
jet's Avatar
jet
Hi, did you find out of you idling problem?
I have just the same probleme as you on my -93 Ecs Cos, 1500 rpm when normal temp, everyhing else working perfect.
Jan Erik
Norway
Old Aug 12, 2005 | 11:30 AM
cos jon's Avatar
cos jon
You'd think ford would have learnt with these valves, i had a fiesta turbo , various XR2i and they all did this. Its an absolute pain when you pull up to traffic lights !!
I found cleaning them didn't work for long, I got a new one in the end.
My escort has sometimes started to think the idle valve doesn't exist in a morning with the car cold, i have to have my foot on the throttle for a few minutes.
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
