A/C diagram
Old 28-01-2013, 05:25 PM
Re Nero
Re Nero's Avatar
Default A/C diagram
Hi guys,
i need help for my Cossy, because dont have the A/C.
I took all components from an Escort Sw 1994...the component are exactly but the problem now comes....... the electrical connections
Any of you have a schema for the connection
Thanks
Jonathan
Old 30-01-2013, 11:23 AM
THE RADMAN
THE RADMAN's Avatar
all the wiring connectors should be already in your loom,unless yours is a very early example,all you need are a couple of relays etc
Old 31-01-2013, 12:49 PM
Re Nero
Re Nero's Avatar
Thanks RADMAN, my cossy is the first T25 exit in '94 ^^
I need relays and fuses...mmm ok i control.
I think i have two possibilities... connect all A/C system as the original or simply "on-off"
Advice guys?
Old 01-02-2013, 05:20 PM
THE RADMAN
THE RADMAN's Avatar
you will need to mod your bulkhead panel for the draintube on the aircon evaporator unit,and cut out the recessed holes in the bulkhead if you want the recirc function to work,otherwise its pretty straightforward,the plugs will all be there taped in to the loom in the appropriate places
Old 03-02-2013, 02:17 PM
Re Nero
Re Nero's Avatar
thank you very much, you helped me a lot.
Saturday began to dismantle the dashboard so I can start to assemble the central block of the A/C
Jonny.
Tank Mike
Ford Focus Diesel
23-02-2022 06:09 PM
THE RADMAN
19-09-2015 12:57 PM
Chopshop85
18-09-2015 06:13 AM
Fudgey
17-09-2015 01:06 PM
ward1174
Other Marques
12-09-2015 03:34 AM
Quick Reply: A/C diagram
