T25 intercooler upgrade with aircon?
I know that the RS500 charge coolers will not fit without the removal of the aircon bits but is there a way to improve the efficiency of this intercooler. Will the chargecooler from the large turbo fit, then fitting an upgrade like thePace one, or are we looking at a water spray system directly onto the intercooler itself?
From: brum/shropshire drives:- frst / escort cossie
it is possible however i opted for mine to be removed just really cant see the point we live in england its cold for 80% of the yr , open the windows the rest
You can fit the standard large turbo one as a straight swap - all you need is the intercooler (I have a mint one for sale ), and the hoses off a LT car (available from Ford). I did this to my car when it was only running 400bhp and also fitted the cold water seperation kit - worked a treat .
RS 500 intercooler with air con?
hi all i was also wondering if it is possible to fit an RS 500 intercooler to a big turbo escos with air con i have been offered one brand new at a cheep price bought by mistake, i live in australia and the car has a/c fitted i dont want to remove it but is it possible to fit the bigger cooler and move the a/c radiator to one side or something it is not a problem to make brackets or pipes as i will gladly do this i just need to know if it will all fit in the space. and if it will work . if some one on here has done it could they post up some pictures anda bit of a write up so that i know what i am up for. thanks for the help.
TONY.
TONY.
