ST Escos block oil jets
Old 14-03-2012, 01:05 PM
DaveCrack
DaveCrack's Avatar
Default ST Escos block oil jets
Does anyone know where I can get these bought?
A friend of mine lost his when rebuilding his engine and our local Ford dealership says they are no longer available from Ford directly...
Old 15-03-2012, 10:22 AM
DaveCrack
DaveCrack's Avatar
No ideas?
Old 15-03-2012, 10:58 AM
grcossie
grcossie's Avatar
I think Havey Gibbs SCS, Mark Shead or Montune, can get you some.
Old 15-03-2012, 11:38 AM
DaveCrack
DaveCrack's Avatar
I'll try them. Thanks for the reply!
Old 28-03-2012, 10:34 AM
LOUPAN
LOUPAN's Avatar
Hi .
Burton power
http://www.ebay.co.uk/itm/Sierra-Escort-Cosworth-YB-Piston-Cooling-Jet-Kit-WRC-/150490116536?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item2309e8f1b8#ht_680wt_1110
Old 28-03-2012, 11:12 AM
DaveCrack
DaveCrack's Avatar
Thanks for the link.
But these don't fit the ST block:
Note: these jets are not suitable as replacements for original jets fitted to T25 Escort blocks.
My mate sent his ST engine for a rebuild and somehow the oil jets got lost. Now we're looking to find new ones or a suitable replacement that doesnt rewuire the block to be machined.
Old 28-03-2012, 07:58 PM
wes
wes's Avatar
Contact Julian Godfrey Engineering +441435 865999
Old 29-03-2012, 05:43 AM
LOUPAN
LOUPAN's Avatar
Excellent point Dave
I was mistaken in the rush
Sorry mate
Old 29-03-2012, 09:02 AM
DaveCrack
DaveCrack's Avatar
No worries! Thanks for the helps anyways!
Old 06-04-2012, 07:04 PM
cossie col
cossie col's Avatar
Be very careful which ones you buy as even the mountune ones have different pressures as this is the reason Mike Rainbirds car melted a piston
Old 07-04-2012, 09:06 AM
LOUPAN
LOUPAN's Avatar
Good morning .
It 's not very reassuring!
What should I know about this parts before buying / mount please ?
Thank you .
Old 07-04-2012, 10:07 AM
DaveCrack
DaveCrack's Avatar
Does anyone know the pressure the std ST ones are set to?
Still looking for original spray jets or suitable replacements that fit without machining the block.
It's a pain in the a*se atm as wen can't re-assemble the engine without these 4 small pieces...
Old 07-04-2012, 12:44 PM
cossie col
cossie col's Avatar
I think it's the mountune ones that have different pressures which is not good as they all need to be the same. Maybe contact Harvey at scs or Mike Rainbird on here or randbmotorsport I'm sure they will put you right
Old 08-04-2012, 09:34 PM
wes
wes's Avatar
As I posted above already CALL Julian Godfrey Engineering +441435 865999, they make them!!!
Forget about the Mountune ones they are totally different to the st ones and aren't interchangeable.
Old 08-04-2012, 09:37 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
Do what the man says
Old 08-04-2012, 09:46 PM
wes
wes's Avatar
I think I've been wearing my invisible jacket again uncle Tony
Old 09-04-2012, 11:43 AM
Cosnada
Cosnada's Avatar
So which are the best to use then? Mountune type or original ST Escos type?
Why are they also more beneficil than sticking with the 2wd type of spray bar?
Old 09-04-2012, 12:52 PM
Turbosystems
Super Moderator
Is anyone actually reading this post
RING JULIAN GODFREY
Old 09-04-2012, 08:03 PM
DaveCrack
DaveCrack's Avatar
RING JULIAN GODFREY
Already sent him an email...
Old 09-04-2012, 09:06 PM
wes
wes's Avatar
From personal experience, hand on heart, the Mountune ones are utter shit
Old 10-04-2012, 12:00 PM
Cosnada
Cosnada's Avatar
Thanks for that wes - are block spray jets considered better than conventional spray bar and if so how come as both are squirting oil under the piston with oil from the pump.
I guess conventional spray bar could not be used with the windage tray as fitted to the late ST Escos?
Old 10-04-2012, 07:16 PM
wes
wes's Avatar
Yes they are considered better as with the spray bar there is one small outlet from the oil pump which is then split into 4, oil jets get oil directly from the main oil way in the block. In the GrpA / WRC engines they also fed oil into it from where the standard oil pressure switch is to even out the oil flow to the rear journals and oil jets. Nothing wrong with the spray bar setup they are used in monster power engines but if i was building one from scratch i would opt for the oil squirters.
I guess manufacturing costs also play a part in why ford (and most manufacturers) went this way as there must be some labour involved in making the spray bars compared to the oil squirters, and the ST engine used a pinto oil pump which is alot simpler and cheaper to make.
Old 10-04-2012, 08:15 PM
Cosnada
Cosnada's Avatar
Thanks mate - and sorry for thread Hi jack
Old 18-04-2012, 04:20 PM
sierrafun
sierrafun's Avatar
burton has these sure for 190 pounds
Old 18-04-2012, 09:43 PM
DaveCrack
DaveCrack's Avatar
Got some from Mr. GODfrey!!! Thanks for the help guys!!!
Old 18-04-2012, 10:50 PM
wes
wes's Avatar
Hooray
I give up
Old 19-04-2012, 08:27 AM
sierrafun
sierrafun's Avatar
[quote=DaveCrack;5883713]Got some from Mr. GODfrey!!! Thanks for the help guys!!![/quo
nice put photos after fit them if you want
Old 19-04-2012, 08:28 AM
Turbosystems
Super Moderator
Hooray
I give up
I gave up too wes
but wtf do you and I know anyway
Old 30-04-2012, 11:39 PM
Karl
Norris Motorsport
Karl's Avatar
Anyone know where I can buy ST oil spray jets from?
Old 17-05-2012, 10:18 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
Try mountune or Ford directly
timsrs
22
24-09-2015 08:14 PM
Quick Reply: ST Escos block oil jets
