ecos running 18's what to lower by ??
car is sitting on set of rondel/engles and standard suspention, it looks fine as it sits but dont no if id prefer it with say -20mm ?
any1 got pics of theres down that amount?
been looking at the GAZ coiloverkits on ebay for £500 whitch sounds resonable,
cheers sean
cheers sean
There has been a few posts like this in the past think the Ahmed springs gave a good ride quality and height, give Mike at R&B a shout and he will sort you out. If you go for GAZ coilovers get them from Chris ( cossymad ) on here he specs them with a different spring rate that give a better ride.
Almost there!
its not so much the '-20mm' drop or whatever the ahmed springs claim to be, dont be fooled into thinking you need a specific drop.
the escos needs to be at a certain height front and rear to enable them to still squat to a slight level, to have the correct roll points to handle correctly, and the ahmed springs achieve this perfectly, matched with a set of Koni's and you will find they will give a much better road feel, overal drive and handling ability than the entry budget level of Gaz coilovers at £500.
but as said, if you do go for Gaz coilovers, order them thru Chris oe Mike as they spec the springs slightly different, Gaz spec them ridiculously hard.
prices here http://www.randbmotorsport.co.uk/shop/Parts.asp?ID=5
now get yourself over to www.escortrscosworth.com
im already on escortrscosworth mate,,, im waiting for you to red name me lololol
sean
I bought them well over a yr ago now, its was under £500 all in from memory but that was a while ago. Well worth doing if your on standard stuff, that and Poly bush the front end.
![](https://passionford.com/forum/images/smilies/tantpis.gif)
Adam Graham
06-09-2015 06:04 AM
