Small turbo engine management light
Last night i changed the shitty bleed valve that was fitted and but back the amal valve the car run sweet for the first 15-20 mins then the two lights that are above the clock came on and the car run ruff as fooook there was also a strong smell of fuel when this happend.
Think it could need setting up!!!
Thanks
Mike
Thanks
Mike
if the amal valve wasn't plugged in before then unplug it again, Theres nothing wrong with bleed valves, there crude but they work! the problem is that there to easy for people to adjust when they don't know what there doing.......
what boost is it running? is it chipped? if you have altered the boost then it may be detecting overboost.
Stu @ M Developments
41
21-08-2015 06:47 AM
