RWD escos conversion
How easy/difficult is it to convert escos to rwd even if you have a doner 2wd sapp to start with? will all the 2wd running gear go straight on or any other mods gotta be done etc
any info would be appreicated
did mine without using a donor 2wd car left the 4x4 susp and hubs in just removed the driveshafts and detached the outer cvs and rebolted them in,obviously removed the diff and sump and i put on a big wing sump, i got a 2wd gearbox mount and modified it to take the t5 box as the floor mounting position is different,and the 2wd prop has to be shortened from memory it was 40 or 45mm and its fine,you need any pics and info let me know and send your email address and i will take and send some hope this helps.
hi mate
spoke to sall he say's you need;
2wd sump
2wd sump gasket
engine oil
2wd speedo cable
2wd sandwich plate
2wd starter motor
make gearbox bracket
shorten 2wd prop
2wd gearbox
gearbox oil
2wd rear beam
if small turbo model(crank pulley)
crank sensor
cheer's
lee
p.s sallmotorsport phone no
07760 476163
2wd sump
2wd sump gasket
engine oil
2wd speedo cable
2wd sandwich plate
2wd starter motor
shorten 2wd prop
2wd gearbox
gearbox oil
2wd rear beam
crank sensor
cheer's
lee
07760 476163
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
