best way to 500hp?
Old 08-12-2008, 08:07 PM
  #41
El Grand Tomismola
El Grand Tomismola's Avatar
Originally Posted by 3i_gaz
yeah andy (AJC) has got an immense escos, as tom said you wont believe how smooth the power delivery is until you actually go in it, i couldent believe how much more driveable and smoother the GT30 seemed compared to a T4.
Compared to my T38
Old 09-12-2008, 08:20 AM
  #42
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
A GT3076R on a 0.63 a/r and a 0.82 a/r only managed 500bhp on Harvey's engine dyno on Paul Ripley's engine at 32psi. The only difference was that the smaller turbine had huge back-pressure at high rpm and a lower boost threshold at low rpm.
Obviously this was on pump fuel, so you could add another 40-50bhp on race fuel .
Old 09-12-2008, 08:24 AM
  #43
tore_tj
Cossie Paranoia
tore_tj's Avatar
Hmm.. I planned to get the 0.63 a/r.. So the 0.82 a/r is better you think? I'd think it would spool much slower?
Old 09-12-2008, 08:29 AM
  #44
Mike Rainbird
Caraholic
Depends what gearing you have on the car. If you have standard gearing and aren't planning to always be high up the rev range / don't do many track days, then the smaller turbine wheel makes a better road car.
If you have 3.9 gearing and use the car a lot on track, then I would advise using the larger turbine, as it will put less strain on the engine at high rpm with the resultant decrease in back-pressure.
If you want to see all the different figures etc, then this is all on Paul Ripley's thread in the photo section.
Old 09-12-2008, 08:49 AM
  #45
Clikettman
Clikettman's Avatar
You talk about wheel turbine size, but the A/R only talks about the turbine housing size, no ?
Old 09-12-2008, 08:52 AM
  #46
Mike Rainbird
Caraholic
Yes, sorry - that is what I meant.
Old 09-12-2008, 09:14 AM
  #47
Clikettman
Clikettman's Avatar
And, sorry I'm a bit off the thread, but what do you think about the gt2876r for a road car ?
I'm looking for something smoother than the T35 A/R.63, with more torque and at least the same power ?
Old 09-12-2008, 10:01 AM
  #48
Mike Rainbird
Caraholic
I have no experience of that turbo. However, looking at the compressor map, it looks a lot more high flow than a T34.
Old 11-12-2008, 12:21 PM
  #49
Karl
Norris Motorsport
Karl's Avatar
Mike,
Paul ripley's turbo must have been the 52 trim version. If you had used the 56 trim version with the A/R70 compressor housing you would have seen nearer 550bhp.
Old 11-12-2008, 12:47 PM
  #50
Mike Rainbird
Caraholic
Originally Posted by Karl
Mike,
Karl,
No, Paul's was the 56 trim A/R 70 compressor in both 0.63 a/r and 0.82 a/r turbine. There was only a few bhp difference recorded (the figures are on Paul's thread), but a big difference in back-pressure (the 0.63 a/r giving 70psi at high rpm at 32psi of boost ).
A GT30 with a 52 trim wheel was also tested, but that only made 475bhp on Harvey's own engine that is currently in his car.
Old 11-12-2008, 01:22 PM
  #51
Karl
Norris Motorsport
Karl's Avatar
Hi Mike,
Well at least that show's Harvey's dyno does not over inflate figures!
What I find strange about harveys results is that the conventional RS500 T4 has a compressor flow of less than 50lb's (Even a 60 trim only just breaks 50lb) where as the GT3076r 56 trim is a 55lb compressor.
This would indicate that harvey's lower power figures are caused by exhaust stage inefficiencies, something I have found NOT to be the case when comparing a 56 trim Gt30 to a 57 trim T4E, especially with the 0.82 exhaust housing!
Still life would be boring if we all had the same results!
Old 11-12-2008, 01:58 PM
  #52
Mike Rainbird
Caraholic
Hi Mike,
I wouldn't have accredited it with that much air flow - more like 52lb:
http://www.turbobygarrett.com/turbob..._700382_12.htm
And Garrett only rate it at 525bhp (according to above) - it made 501bhp on Paul's engine with a standard YBP inlet manifold. It may have made a bit more with something else, as this is really the limit of this inlet.
0.82 a/r turbine housing
RPM Bst BP Torque BHP
3000 08 04 199.7 116.9
3500 28 15 360.5 242.7
4000 32 20 386.3 293.1
4500 32 21 404.9 348.7
5000 32 24 394.9 374.7
5500 32 26 394.4 414.7
6000 32 28 395.1 450.7
6500 32 32 389.6 483.7
7000 32 35 376.3 501.5
7500 32 40 341.3 485.4
0.63 a/r turbine housing
3000 13 10 238.8 138.1
3500 32 24 389.4 259.2
4000 32 27 388.3 297.5
4500 32 31 404.1 345.0
5000 32 34 397.0 379.7
5500 32 37 393.0 413.2
6000 32 39 398.7 457.9
6500 32 44 382.7 474.4
7000 32 56 370.8 495.6
7500 32 65 340.3 485.3
Old 11-12-2008, 02:07 PM
  #53
Karl
Norris Motorsport
Karl's Avatar
Hi Mike,
The problem will using the YBP inlet is that you are not giving the turbo it's maximum ability to create power, and hence even you must agree your argument is flawed about it having only a 500bhp capability, if the engine you tested it on clearly has "other" flow restriction. I think also a lot of people do not realise that exhaust back pressure is influenced by intake efficiency (i.e. total energy consumed in the process of compressing the intake charge and forcing it through the entire intake system, through the head ports/valves and into the cylinder.)
Old 11-12-2008, 02:19 PM
  #54
Altratz
Altratz's Avatar
Can I ask a question? If there is huge back pressure pre-turbine, would it not be possible to bleed the excess off using an external wastegate set-up, but leaving enough gas to keep it at max boost?
Old 11-12-2008, 02:21 PM
  #55
Mike Rainbird
Caraholic
Hi Mike,
I agree, hence why I mentioned it , but I still don't think that this turbo is quite a 550bhp one, as the 52 trim turbo that you mentioned that "should" make 500bhp (but only did 475bhp) was tested on an engine with no flow restrictions (well only 620bhp ones - the limit of the Mountune roller-barell ).
Also, the back-pressure readings jumped astronomically with the smaller rear turbine housing (virtually doubling), but only lost 5bhp....
I would be interested in knowing where you get your comparative figures from?
I suppose the true test of the turbo would be to stick on an engine with no flow restrictions on the dyno .
Old 11-12-2008, 02:40 PM
  #56
Karl
Norris Motorsport
Karl's Avatar
Hi Mike,
All my figures are based on mapping data logging. This includes, individial EGT's, pre turbo back pressure, post turbo back pressure, intake system pressure tappings in turbo inlet hose, turbo outlet, intercooler outlet and inlet manifold pressure.
I then map the engine at numerous boost levels, paying particular note to AFR and injector pulse width. This is also backed up by real time performance analysis, which allows me to analyse any aspect of the vehcile performance. For example I can see exaclty how long the engine takes to accelerate from say 4000rpm to 8000rpm, or any resolution for that matter.
As such when I do research on different turbos on the same engine it is VERY clear what the results are, both from direct comparison of fuel consumption and of course real time acceleration data.
It does take me many hours to comprehensively analyse every setup, but I now have an extremely extensive data base of what virtually every main stream turbo can do on different spec YB's (AND CVH!!).
I mean who on earth would have believed I could manage 173mph on a CVH ERST running the stock exhaust manifold, which once was believed to be good for only 300bhp! The latest engine performance suggests we are well on for exceeding 180mph! Not bad for a 1.7CVH!
Old 11-12-2008, 02:41 PM
  #57
tore_tj
Cossie Paranoia
tore_tj's Avatar
so what inlet should one use then? I've got a ybp one that I was planning to use..
Old 11-12-2008, 02:45 PM
  #58
Karl
Norris Motorsport
Karl's Avatar
YBP is fine for up to 500bhp, but I would'nt suggest using it beyond that!
One thing for sure is DON'T use a swedish style plenum, they do not give equal EGT's on boost. I have been harping on about this for years but no one listens!! I have dozens of engine data running these plenums and all are down right dangerous on cylinder number 3/4 EGT's!
This problem arises from the fact we have to map via average AFR (i.e.the AFR of all 4 cylinders), and in order to maintain no more than 920DegC on cylinder 4 on a swedish plenum requires AFR's in the 10's! By comparison cylinder number 1 is usually up to 150DegC cooler!
Hence now all swedish plenum'ed cars are banned from my workshop IF in for mapping, as I refuse to lose an engine from poor inlet manifold design!
Old 11-12-2008, 02:50 PM
  #59
tore_tj
Cossie Paranoia
tore_tj's Avatar
Won't use swedish style because it looks crap
no use in a spacer on a ybp then?
Old 11-12-2008, 02:52 PM
  #60
RWD_cossie_wil
RWD_cossie_wil's Avatar
Hence now all swedish plenum'ed cars are banned form my workshop IF in for mapping, as I refuse to keep lose an engine from poor inlet manifold design!
What inlet would you reccomend then Karl? Also Did you see Altratz's question above?
Old 11-12-2008, 02:56 PM
  #61
Lee Ivatt
Shizzle My Nizzle
Lee Ivatt's Avatar
Originally Posted by MatthiasBoldt
Hello
what is a good setup for 500 hp / atw?
Buy a V8 jobs a good'un.
Easy and RELIABLE 500 bhp
Or chuck twice the money at a YB and expect to be rebuilding it in 6 months after it goes pop
Old 11-12-2008, 03:00 PM
  #62
Karl
Norris Motorsport
Karl's Avatar
YBP with plenum spacer is ok for around 520bhp and suits the GT3076 turbo well.
Beyond 500 bhp I design and manufacture my own intakes, all centre entry and all with virtual 100% equal EGT's on full boost!
In answer to altraz's question above all std garrett GT30's are external wastegate, I would'nt use any of the modded internal gated items for anything other than an ornament!
Old 11-12-2008, 03:13 PM
  #63
tore_tj
Cossie Paranoia
tore_tj's Avatar
One question Karl when you're around ().
I'm Doing this as a low comp(7.2) engine on solid lifters. Any suggestions on cam choice? And can you map for a longer powerband on solids or do the turbo run out after 7,5k like on Ripleys?
Old 11-12-2008, 03:16 PM
  #64
Mike Rainbird
Caraholic
Karl,
You shouldn't tar all these plenums with same brush, as the true Swedish ones have been dyno tested in the same way as you have described and have no more than 2% disparity between EGTs per cylinder.
This is why I harp on about people buying cheap untested / unproven copies (most of which either blow to pieces due to being made of insufficient gauge or are as you describe, with un-even flow distribution) .
Old 11-12-2008, 03:22 PM
  #65
Karl
Norris Motorsport
Karl's Avatar
Solid lifter cams are far superior to hyraulics in every way. If you anticipate revs over 7500rpm then go solid lifter!
Regarding power band, our sunbeam race car usually runs with a 8800 rpm limit using gT3076R. Peak torque is around 6500 - 7000rpm but holds on well to the 8800 limit!
It's pointless me quoting you figures are there are too many variables. Speak to your engine builder regarding your required power band and spec the engine appropriately.
For the record I love revs, so am quite happy to lose 500rpm low down for an extra 1000rpm top end, but as always its horses for courses!
Old 11-12-2008, 03:25 PM
  #66
tore_tj
Cossie Paranoia
tore_tj's Avatar
Thanks. Just need to find me someone to make some cams
Old 11-12-2008, 03:50 PM
  #67
Mike Rainbird
Caraholic
Solid lifter cams are no problem .
Old 11-12-2008, 03:53 PM
  #68
PGT
PGT's Avatar
great thread - this is what this forum should consist of!
Old 11-12-2008, 04:04 PM
  #69
tore_tj
Cossie Paranoia
tore_tj's Avatar
Prices on your website?
Old 11-12-2008, 04:05 PM
  #70
Mike Rainbird
Caraholic
Not this time . But you're learning .
Old 11-12-2008, 04:09 PM
  #71
tore_tj
Cossie Paranoia
tore_tj's Avatar
Ok tell me the secrets then how much and should I really trust you with picking me a profile
Old 11-12-2008, 04:12 PM
  #72
tore_tj
Cossie Paranoia
tore_tj's Avatar
you can pm me if you're shy
Old 11-12-2008, 07:16 PM
  #73
cossiemanden
DANISH cosworth abuser
cossiemanden's Avatar
Hi karl.
As mike says, the genuine sweedish plenums ARE working as it should.
They are tested on a dynobench and are having just about 2-3 deg diff from cyl 1 thru 4 on full boost, but only the latest one counts, and NOT the ones that are on ebay with the angled throttlebody.
My engine has the latest one and we have monitored the egt on all 4 and they diff arr 10 dg on my engine, but that can be many things.
Only prob with theese inlets are when on vacum, then the 1. and 2. cyl get to much air, so have to correct for that.
Old 11-12-2008, 07:40 PM
  #74
KSA-Cossie
KSA-Cossie's Avatar
SO true m8.
Old 11-12-2008, 07:54 PM
  #75
tore_tj
Cossie Paranoia
tore_tj's Avatar
This should be in the tech section soon
Old 11-12-2008, 08:05 PM
  #76
AndyPen
AndyPen's Avatar
I have 437 ATW and guess around 470 at the fly. Not up to what you are asking I know. This is with BD14 and 15, lots of porting and low comp. Original T4. I am only running 4 greys so that is the limitation really.
http://uk.youtube.com/watch?v=HoHp0sZ3zjg
Just for comparisons
Old 16-12-2008, 03:42 AM
  #77
c0ss1e9i6
Franco
c0ss1e9i6's Avatar
Originally Posted by El Grand Tomismola
Basically a fair bit of money
I think you are the master of understatement!
A truck load of money and a lot of blood sweat and tears would be more apt!
Mine is built around:
AVA engine (similar to Neil A and Euan)
Roller bearing T4.
1000cc injectors.
Custom fuel pump set up.
Omex 700 ECU.
(Mapped by AVA)
Currently at 370 ATW (400 ish ATF) but I've got a Swedish plenum to go on and then I'm after a new gearbox so a bit more grunt can be thrown at it!
Old 03-03-2009, 01:47 PM
  #78
Oppliger Motorsport
Romain
Oppliger Motorsport's Avatar
200 block with long studs
ported head
forged pistons
std rods and cranck are ok
cams
gt30 or gt35
new oil pump
breather system
good ecu
etc
Old 04-03-2009, 03:22 PM
  #79
andy escos
andy escos's Avatar
very interesting thread keep it going mike ,karl .mike would i be better off with solid lifters on my car .
Old 04-03-2009, 03:28 PM
  #80
mad russell
Volvo Mad
mad russell's Avatar
The best way to a genuine 500 hp is give the engine/and car to Mark Shead at Madevelopments no bull just genuine hp
Russ
Quick Reply: best way to 500hp?
