Best replacement speakers for escoss?
looking to replace the speakers in my escoss front and rear, just want something that is standard fitting but much better qaulity, any ideas?
Craig
Craig
Almost there!
it would all depend on your budget really as the options could be endless.
the size of the speakers are a fairly common size and changing them for a replacement will be an easy task, as most stereo shops could do it in no time and probably keep them in stock.
in my old Escos i had Focal Utopia's, quite pricey for what they are, but just like other speakers they fitted directly into the standard positions and holes with no cutting or nasty alterations to what was on show - it all looked factory.
your best bet will be to nip into a decent local car stereo specialist, they should be happy to help, after all your going in with a nice car and wanting to put money in there pockets
Cheers Kelv.
I'm quite prepared to spend a few hundred quid, just wondered what speakers others had used and how they performed, so I would have an idea what would give me the best results, with a standard look.
Craig
Craig
Because I've tried to pass some Focal in 13.5cm (5.3 inches ??) in the front doorcards abd they were to big.
I've put a pair of slim separated Alpine kit, wich sounds quite good.
And a pair of elliptical Focal on the parcel.
For Craig, you can find in sounds shops plastics items to fit 13.5cm or 16.5cm speakers on the rear standard places
Cossie Paranoia
Do you remember the size ?
For Craig, you can find in sounds shops plastics items to fit 13.5cm or 16.5cm speakers on the rear standard places![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Cossie Paranoia
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
