Cosworth flywheel
The problem is, that my new sinter clutch`s center, touch flywheel before the pucks, and yes it`s the right way. Seems like a production failure
For a twin plate 7 1/4" or 7.5" clutch you will need a big turbo flywheel, it has the smallest diameter across the face, think it is 130mm not 170 or somthing similar, it is what I run on my Escos (was small turbo , flywheel had to be changed) as I have a twinplate ...
Give martin a ring at reyland, thats who I got my clutch kit through and he sorted the flywheel machining for me.
Mine ones are bouht from big turbo Escort, and yes it`s 130mm.
I have found the problem, it`s was a production failure on the clutch, a new one is just around the corner
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
