Is this my problem ?
Hi my car has been over fueling on tick over and running poor, it has also been blowing the Lamda sensor fuse and cutting the car out.
But last week I found this sensor shorting out.
Would this cause the problems ?
Dave.
Dave.
As said that's a oil pressure sender, but how can someone be so stupid just doing up the nut!!
I would have agood look at the lambda sensor wiring as this is so close to the exhaust, in case it has melted somehwere near.
Me mate had the same fault, had us baffled for ages kept blowing the fuse, turned out it was the lambda sensor wires had melted toghether
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
